Home > Technical Chat > Front mounted radiator conversion
adcyork
Member #: 6807
York
I'm in the process of researching converting to a front mounted radiator and i'm wondering which radiators from other cars fit into the front of a round nose?
I'm running megajolt with the standard oil filter housing, alternator and starter motor so i have a bit more room at the front of the engine than standard.
Also can anyone show me some pics of the radiators they have fitted?
Thanks
Andrew
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
Just use a front mounted mini radiator? I mean, a little ingenuity and you could fit just about any rad up front...
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Cinquicento rads are very cheap and cost next to nothing on ebay. Search Cinquicento on here and you will find lots of people running them with good install pics (Matty and Ben spring to mind)
On 30th Apr, 2010 Rod S said:
Gary's description is best
METRO MK1 RAD .
haimesyboi
Member #: 5702
Cornwall
Cinquicento. Cheap, light and efficient. Hoses both on the same side and a fan switch, ideal.
lee439
Member #: 8894
i have mounted a mk 2 glof rad in the front of mine but mines a clubman i bought a brand new one off the bay for £30 delivered there are loads out there take a trip to the scrappy with a tape measure also depends on it you want to cut a bit more out to have it even flusher
the car is finished now if you want pics of it with the new rad in and dizzy clearance ect let me know
