Home > Help Needed / General Tech Chat > Crank help
TomBooth
Member #: 2814
Mansfield - Notts
Hi all, I'm looking to fit a new crank in my engine after the flywheel decided to make an early escape from the crank nose.
I've had an offer in my club of a still boxed 12G1505, still in wax paper. Now going on this website..
http://www.minimania.com/web/SCatagory/ENG...27/ArticleV.cfm
Going from the 1.75" big ends on the 12g1505, and the CAM6232 having 1.75" big ends, it looks to me like it'll fit with my metro turbo engine. Are the mains any different? Any difference in oil feeds on the cranks? Or any significant differences in the cranks that'll stop me using it? Also any suggestions wether I should have the crank worked slightly? Hardening etc? Will the 12g1505 stand the extra power?
Appologies for the n00bish question, but I've kinda been thrown into the deep end with this crank problem. I've never had any dealings with fitting cranks and what not so I wanted to be sure before I threw more money into the engine to find out it was wasted!
Tom
Edited by TomBooth on 19th Apr, 2010.
link dont work
TomBooth
Member #: 2814
Mansfield - Notts
:S I can't get it to work, this is the 2 main pieces of info on that page that matter anyway...
12G1505 1275cc - Non-S, EN16T with 1.75" dia. big ends
CAM6232* 1275cc - Rolled-fillet radius on bearing journals, A+ with 1.75" dia. big ends
So long as I'm right in thinking the CAM 6362 is the turbo crank?
cam 6232 is std A+ crank and also fitted to some tubro engines. Cam 6581 is another A+ crank only fitted to some turbo engines.
6232 is the standard A+ crank. Some turbo's got 6581.
The 12G1505 should work fine, I don't think it has the rolled-fillet radius on them, however I am not sure of the impact this has?
12G1505 (or 1505A) is the early (pre A+) 1275 crank.
I have three of them and one is in my turbo engine (yet to be proven).
They were used with the earlier main bearings which have a groove all around whereas the later A+ main bearings had no groove in the bottom.
BUT, there are quite a few threads on whether this makes any difference, ie, should the main be cross drilled if used with the plain bottom shell.
you must have a special crank if the flywheel is fixed to its nose *happy*
To be honest I would use the new crank, but cross drill and harden it. Job done!
On 19th Apr, 2010 mowog said:
Yes, cranks fitted with these bearing (plain lower) should be cross drilled even for moderate use. I cannot understand why this was not done in the factory.
whats is moderate use, the standard metro turbo had 90 hp and was caned mercilessly by its owners for many a mile, yet these cranks come out of high milage engines with perfect bearings nine times out of ten,
maybe one day i'll try crossdrilled mains and see if it makes any difference but as of now its big ends only for me,
carl
Is the forum going mental or is Carl so quick that he replied before mowog asked the question?
its done it again, i am fast but not time travel bloody fast,
The time is still correct! lol
mowog
Member #: 6792
WTF?!?!
Light speed broadband, the fastest tinternet in the known galaxy *hehe!*
TomBooth
Member #: 2814
Mansfield - Notts
*hehe!* TM clock strikes again!
So the general opinion is it'll be fine, just with the earlier grooved bearings?
Would it be worth having it cross drilled anyway for the life of the crank?
In theory, all A+ engines with plain bearings should have failed their big-ends. This does not seem to happen, and I cannot understand why. I've NEVER seen a factory crank with crossdrilled main either. (Apart from Cooper S ones)
However, I would always use the grooved main bearing i f I had the choice.
The 1505 would be fine for turbo use. Carls says it pays to have it hardened, so this is sound advice.
mowog
Member #: 6792
I've seen a few Big End Bearing failures because of the lack of this feature.
Few being the operative word?
There have been hundreds of thousands of A+ series engines without failure but only a few with failure, why does that make it bad?
are you now talking about big ends or mains or both, be cause youv'e gone from one to the other,
carl
TomBooth
Member #: 2814
Mansfield - Notts
Without wanting to sound asif I'm ignoring replies, I'm just after a deffinate answer (I have taken on board the replies, and I will be having the crank hardened/crossdrilled).
The crank will be fine in a metro turbo A+ block, will the lack of Rolled-fillet radius on the 12g1505 crank make any difference?
So (Just to get it into my head) Crank hardened, cross drilled, using the earlier bearings with the groove, and I should be good to go?
Like I said, sorry for the breakdown of whats said, I just want to be overly sure of what I'll need to do/buy to get my engine back on the road and sorted!
Tom.
Edited by TomBooth on 22nd Apr, 2010.
No, use the groved bearing is NOT crossdrilling and cross drill if using the plain bearing. Unless you listen to Carl (which is good advice) and use the plain bearing on the mains and DON'T cross drill.
Only crossdrill the bigends.
For what it's worth, can you even get main bearings with a groove for A+ fitment?
I don't think you can. Rich keep telling me that it will be more and more difficult to get regular bearings in the future as well..
When using the plain main bearings, it's the mains that should be crossdrilled.
The 1505 will be fine. Don't worry about it at all. It's of the same material as the 6232.
There is definately conflicting advice here. As follows
Mowog - if using plain bearings on mains or bigends always crossdrill
Fastcarl - if using plain bearings on bigends then crossdrill, if on mains don't bother
Vegard - Agrees with Mowog, but would use groved bearings (although these are not available.)
Simples!!
You don't need to crossdrill big ends because of the plain mains. It's the supply to the BEs which is cruical, and the plain mains prevents this half of the time.
HOWEVER, as Carl states, it seems as this is not a problem.
