| Home > Help Needed / General Tech Chat > Pre Verto Return Spring | |||||||
25th Jan, 2005 at 09:22:57pm
I remember reading on the manchester minis website and artical about clutches by Turbo Dave mentioned reversing the spring? |
26th Jan, 2005 at 01:49:12am
It works fine without one,the plate goes on the bleed nipple
26th Jan, 2005 at 11:14:14am
Mine has worked without one for ages now...
AlexF |
26th Jan, 2005 at 07:39:17pm
The return spring is just there to pull the clutch arm back all the way to the stop (bolt & lock nut on cover) so the release bearing is clear of the diaphram. -MINI CLUBMAN 1380 TURBO- |
26th Jan, 2005 at 10:31:10pm
I have spent this evening putting my clutch together - all seems fine.
26th Jan, 2005 at 11:39:16pm
I can remember years ago having a arm bent up the garage with oxy acet,as the clutch wouldn't release fully (not enough push)
Edited by Dangerous on 26th Jan, 2005.
