| Home > Help Needed / General Tech Chat > TURBO HELP. I CANT HIT BOOST! | |||||||
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
20th Apr, 2010 at 01:09:47pm
Recently rebuild metro turbo 20 thou over. Std cam and 8.5:1 compression, Only mods made are a small intercooler from a mazda rx7 and t2 turbo was fully rebuilt and hi-flowed
20th Apr, 2010 at 01:17:46pm
Get the mixture sorted then go from there. Avonbar sell some higher boost needles as a starting point. Is fuel pressure rising with boost?
20th Apr, 2010 at 01:32:32pm
ok tah, yes fuel pressure is rising with boost. :)
![]() 299 Posts Member #: 2814 Senior Member Mansfield - Notts |
20th Apr, 2010 at 01:37:57pm
Is the fuel bowl getting pressure? Have you fitted the correct plenum-carb gasket? |
20th Apr, 2010 at 01:52:26pm
yes. I have even plumbed pressure from the plenum into the fuel bowl. |
20th Apr, 2010 at 01:53:22pm
Sounds to me like the wastegate is open all the time. Are you sure the pre-load is set up correctly? http://www.twin-turbo.co.uk
20th Apr, 2010 at 02:04:27pm
yep 100% set up even had it all checked over. |
20th Apr, 2010 at 02:12:24pm
is it actually running pulling properly upto high revs imo if it was fuel or even spark it would hit a wall as the boost started to build, i would edge my bets it not boosting soo look at wasegate, turbo, blocked down pipe, seriousl restricted inlet?... even the rubber poppet in the plenum?
Yes i moved to the darkside |
21st Apr, 2010 at 12:11:43am
it seems the seals in the carb has air coming out the dash pot.
21st Apr, 2010 at 08:01:38am
It would have to be leaking massively to wipe out all the boost.
21st Apr, 2010 at 12:38:39pm
thanks for the reply's guys.
21st Apr, 2010 at 12:55:28pm
Is this the classic wrong gasket between plenum and carb?
