| Home > Technical Chat > Injected 7 port turbo | |||||||
17 Posts Member #: 8805 Member |
21st Apr, 2010 at 10:14:43am
Hi All,
21st Apr, 2010 at 10:20:00am
Sorry, to add I have read through most of the threads about turbo choice and have seen some use a T2 and also T17's But their is a lot of conflicting info on each. I was leaning towards the T17 but have since read threads saying there are better choices out there. So these are??? Thanks All |
21st Apr, 2010 at 10:24:47am
The intended use for the car might also help with turbo selection. I will be a trackday/Hillclimb car. |
21st Apr, 2010 at 10:25:10am
Search for GT2056 on here. It's not a ball bearing turbo but may be what you are looking for.
21st Apr, 2010 at 10:25:34am
21st Apr, 2010 at 10:27:10am
BTW Welcome to TM! If something is worth doing, it's worth doing half of. |
21st Apr, 2010 at 10:28:50am
Woops. Its a minisport casting with turbo exhaust guides and sodium valves, Ti caps and heaps of porting work. I got the casting cheap and they are pretty rare in Australia, other than the Elder Heads but they are a bit spendy. |
21st Apr, 2010 at 10:30:00am
Cheers. Glad I found you all. |
21st Apr, 2010 at 10:37:32am
As John said the GT2056 will give you the most efficient air flow, but is not ball bearing. It should provide enough air flow for around 270hp.
21st Apr, 2010 at 10:46:17am
Paul, have you noticed any drawbacks to only being oilcooled? Or did you fit the T17 housing? |
21st Apr, 2010 at 10:48:35am
I've not run it yet, so I cannot comment from personal experience.
21st Apr, 2010 at 11:34:12am
Thanks guys, decision made. |
21st Apr, 2010 at 12:05:32pm
What about the TD04? http://www.twin-turbo.co.uk
21st Apr, 2010 at 12:11:50pm
Good call Ben. Cheap as chips too. If something is worth doing, it's worth doing half of. |
![]() 825 Posts Member #: 2208 Post Whore Essex |
21st Apr, 2010 at 12:39:22pm
look up mini13, he's running a 7 port turbo with fuel injected, very good engine build! |
21st Apr, 2010 at 10:08:14pm
till it went bang....
21st Apr, 2010 at 10:47:26pm
Hey Mini 13,
21st Apr, 2010 at 10:52:32pm
On 21st Apr, 2010 Pantsly said:
Hey Mini 13, Ive been reading most of your stuff, what ways do you think disaster could have been avoided? I think it all went wrong when the sperm entered the egg tbh |
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
21st Apr, 2010 at 11:16:45pm
21st Apr, 2010 at 11:24:05pm
I think stop trying to be flash and fit a chain would have prevented it. In the 13's at last!.. Just |
22nd Apr, 2010 at 08:26:59am
both good points and true... On 28th Aug, 2011 Kean said:
22nd Apr, 2010 at 07:01:32pm
anyway,
Hey Mini 13, Ive been reading most of your stuff, what ways do you think disaster could have been avoided? On 28th Aug, 2011 Kean said:
203 Posts Member #: 1734 Senior Member Lancaster |
22nd Apr, 2010 at 09:01:46pm
I agree with mini13 on the stat. I run a 74 degree C stat. works fine on that. I did notice the temps would start to run away too much with the higher 82 degree C temp stats. |
23rd Apr, 2010 at 09:38:51am
I dont think i'm going to run a thermostat. Leaning towards a Davies Craig Electric pump with the control module. It has some nice features like running after the engine is shut off to stop heat soak and can set the temp to anything I want. Worth a try.... |
23rd Apr, 2010 at 09:57:03am
On 23rd Apr, 2010 Pantsly said:
I dont think i'm going to run a thermostat. Leaning towards a Davies Craig Electric pump with the control module. It has some nice features like running after the engine is shut off to stop heat soak and can set the temp to anything I want. Worth a try.... Running without a thermostat is plain stupid. On 13th Jul, 2012 Ben H said:
