| Home > Help Needed / General Tech Chat > Any bodywork type people? | |||||||
![]() 611 Posts Member #: 5222 Post Whore Northumberland |
21st Apr, 2010 at 04:56:12pm
I have a bit of a fetish for tools |
21st Apr, 2010 at 05:16:52pm
Id just put some jenolite on it and carry on as normal |
21st Apr, 2010 at 05:34:49pm
Has it been repaired previously? There looks to be a weld line just to the right of the left hand bung hole.
21st Apr, 2010 at 05:38:16pm
if its the original panel I'd treat it with rust converter and paint it; hard to tell how bad it is without seeing it in the flesh though |
21st Apr, 2010 at 06:16:40pm
por15 Crystal Sound Audio said:
21st Apr, 2010 at 07:23:50pm
It's certainly a repair panel in there, just look at the top edge in the first photo.... Five stitch welds and the rest is not great.
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
21st Apr, 2010 at 07:52:32pm
I get the feeling the repair is the bottom of the bulk head rather than the floor pan, i think i can see more stick welds running from the right up on a diagonal? if your are a confident welder i would cut it out. |
21st Apr, 2010 at 08:30:44pm
21st Apr, 2010 at 08:38:07pm
is the welding not due to strengthening works? |
21st Apr, 2010 at 09:00:37pm
clean it with a wire wheel in a angle grinder (if thats not what youve done already) treat it with one of the above mentioned products. will need patching one day but depending on use that may be a few years no longer a series, but still 1.3 turbo.
21st Apr, 2010 at 09:10:35pm
Isnt it just seam stitching? |
22nd Apr, 2010 at 08:34:08am
On 21st Apr, 2010 apbellamy said:
Is this your/Iain's old miglia? On 21st Apr, 2010 Rob Gavin said:
is the welding not due to strengthening works? On 21st Apr, 2010 Nic said:
Isnt it just seam stitching? Yes,yes and yes to the above,the floor panel is the original but stitched to the front bulkhead & flitch panels as well as the original spot welds. Might just cut it out,couldnt get an easier section to repair to be fair - probably just being a lazy sod! Cheers Ross. On 20th Jan, 2011 apbellamy said:
22nd Apr, 2010 at 12:20:46pm
I'd not replace it, think of the weight your saving On 15th May, 2009 TurboDave said:
22nd Apr, 2010 at 04:22:23pm
On 22nd Apr, 2010 Jimster said:
I'd not replace it, think of the weight your saving Good point,I might wipe off the layer of dust thats on top of the car I will probably save the same again.Extreme weight saving! On 20th Jan, 2011 apbellamy said:
22nd Apr, 2010 at 10:15:26pm
Once rust has gotten to a panel no matter what you do it will come back.
Own the day
23rd Apr, 2010 at 08:10:10am
Problem solved,hacked it out with the grinder yesterday night.
