| Home > Wanted > Layshaft, Primary C washer, verto keyway | |||||||
22nd Apr, 2010 at 10:08:22am
As above, It turns out my layshaft is the 3 step type, and the 2 spares I have are the 2 step type...typical. Has anyone got one is good condition?
![]() 299 Posts Member #: 2814 Senior Member Mansfield - Notts |
22nd Apr, 2010 at 10:55:00am
Have a look on Ebay for the Keyway. I'm after one an they seemed to be a fair bit cheaper on there then minispares/sport.
Edited by TomBooth on 22nd Apr, 2010. |
22nd Apr, 2010 at 12:21:41pm
I have one layshaft of the type that I think is what you mean by 3 step which has the tiniest beginnings of pitting - I'll photo later (need to charge my camera batteries).
22nd Apr, 2010 at 12:32:48pm
Ok cheers rod. Mine has a groove worn in it. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
22nd Apr, 2010 at 01:00:18pm
No grooves or I wouldn't have even kept it (it came out of a box I bought only for the later casing).
22nd Apr, 2010 at 01:12:46pm
Matty, with your expected hp and torque I would buy the Swiftune Key (you wont be able to use the bolt though), its not a verto one, but it won't matter.
Edited by Sprocket on 22nd Apr, 2010. On 26th Oct, 2004 TurboDave16v said:
22nd Apr, 2010 at 01:55:14pm
Couldn't get the macro to work right on the camera (possibly too shiney?) so put on my A4 scanner...
22nd Apr, 2010 at 02:17:42pm
To be honest Rod, both my spare ones had the same pitting at the end, it was unmeasurable with a mic so wasn't bothered. Mine has a groove in the centre of the large diameter bit right where the bearing has been running.
Edited by matty on 22nd Apr, 2010. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
22nd Apr, 2010 at 02:28:28pm
There are some quality items to be had on ebay....
22nd Apr, 2010 at 02:35:54pm
On 22nd Apr, 2010 matty said:
Im guessing its going to be better than a new one from minispares? An interesting question... Certainly some of the older stuff (even when worn) is better than the new "copies" but it's hard to be specific on a single item (hence my comment about has anyone else got a view on this). I'm using all pre-A-plus gear trains in my gearboxes because I think the material is better and the helix angles are better so, as I said, this came out of a gearbox that I only bought for the later (stronger) casing. So it's a bit unknown but if you want it, just cost of postage as the small beginnings of pitting are just visible. But if someone has an old one that is perfect (gold dust???) I won't be offended :) Schrödinger's cat - so which one am I ??? |
22nd Apr, 2010 at 02:53:26pm
Ah ive just re-read your original post. I thought you meant the pitting on the end, hmm I see what you mean about the pitting on the bearing surface, I missed that first time round. Edited by matty on 22nd Apr, 2010. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
22nd Apr, 2010 at 08:24:58pm
Im an idiot!!! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
1391 Posts Member #: 1686 Post Whore Oxford |
22nd Apr, 2010 at 09:26:22pm
I`m sure ive got a few spare c washer`s.
OMG Robert that's a big one |
22nd Apr, 2010 at 10:22:46pm
Cheers Sam, I'll Pm you my address.
24th Apr, 2010 at 08:38:00pm
Still after an 'A' layshaft, I called minispeed and minispares, both out of stock. :( https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
24th Apr, 2010 at 09:24:46pm
http://cgi.ebay.co.uk/Mini-Competition-Lay...=item5d2627a63b
24th Apr, 2010 at 10:13:48pm
On 24th Apr, 2010 Sprocket said:
http://cgi.ebay.co.uk/Mini-Competition-Layshaft-Austin-Morris-Cooper-Rover_W0QQitemZ400072091195QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item5d2627a63b ??? LOL,LOL,LOL. Imagine your swiming in the Australian barrier reef, you see a big dorsal fine, and ask yourself , shall i give this fin a wide betth or not, could retro minis be that dorsol fin, i think possibly so, |
24th Apr, 2010 at 10:25:27pm
Not even If your desperate though Carl?
24th Apr, 2010 at 10:59:13pm
I did see that one, but I'd rather put my scored one back in tbh. lol
![]() 465 Posts Member #: 1972 Senior Member Worcester |
25th Apr, 2010 at 08:07:09am
Ive prob got some knocking about mate i will have a look in a bit.
Edited by retroracer1380 on 25th Apr, 2010. |
26th Apr, 2010 at 10:11:32am
The ebay one will be a MiniSpares one - he is a biggish customer of MSNorth. Buys from MS and then sells with a healthy mark up on ebay (although with their fees now that can't be profitable!).
27th Apr, 2010 at 02:03:53pm
Looks like im going to have to risk the ebay one, they're like hens teeth to get hold of. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
