Home > Help Needed / General Tech Chat > weight removal
blister
Member #: 2590
Croydon
so far on my mini build to remove weight
cut out the rear seat overhang and both door bins,
fitted polycarb windows thanks to MARKGTT,
removed the rear shelf and replace with light weight swaged alloy,
all sound deadening has now gone
carpets removed,
alloy 4 pot calipers and 7.5 discs
spare wheels gone,
removed dashboard,
fitted bucketseats,
i now got a few more questions what else can i get weight out of on the cheap,
and also what light weight seats are there i have searched all over the internet and only found expensive one that are 400 for one seat!
http://cgi.ebay.co.uk/Stockcar-Autograss-B...=item439ebfdc6c
http://cgi.ebay.co.uk/KIRKEY-ALLOY-RACE-SE...=item588605efa2
Edited by Joe C on 22nd Apr, 2010.
blister
Member #: 2590
Croydon
is that the lightest seat available?
i have never seen one like that before looks like a right trap
Head lining, supporting poles and the metal that holds it all up.
drill holes in everything!
i belive they are pretty light,
probably not that comfy on a long journey though.
Fit ally skins to your doors, remove the winder mechanism and cut the inner skin out. That was the biggest single weight loss of mine.
blister
Member #: 2590
Croydon
sorry didnt mention i have cut the inner skins out the doors and removed the winder mechanisms,
was after a more comfy style seat mini13,
and how much is in the headlining gear?
Basically look at everything non structural and decide whether it is needed to support or hold anything. If it isn't remove it or drill it.
Rob H has even drilled holes in the door hinges.
It gets obsessive.
I'm now fabricating a rear beam from scratch for my car, because all the usual offerings seem way to heavy.
The heater weighs 5KG and that's without hoses and coolant.
EDIT:I cut out the frame for the head lining on my car and that was 1KG by itself
Edited by apbellamy on 22nd Apr, 2010.
blister
Member #: 2590
Croydon
top dash rail and how do i go about removing all the bonnet braces?
plus you'll loose a stone from all the shivering.
blister
Member #: 2590
Croydon
oh i have also removed the heater and all the pipes
Angle grinder *evil*
Also - make sure you have a good poo before you go anywhere, maybe shave too.
blister
Member #: 2590
Croydon
reason i asked about how do i remove the bonnet braces was because the bonnet stand is attached to it as well as hinge mounts so i guess i leave about a inch from these?
Johnny
Member #: 6926
Accrington
carbon roof? or fibre glass
carbon or firbre glass front end?
rear beam axel?
just have 1 seat not 2
carbon boot lid?
buy a fibreglass shell? lol and titanium front subframe?
Silly ideas....
1380 engine because there is less material in the block ? *happy*
ultra light kad flywheels etc, will loose quite a lot of weight with them sorta mods.
shorty mini? *happy*
It gets obsessive.
It doesn't stop there, I've found plenty more things to drill, as Mr Austin once told me, you have to look at every item on the car and ask yourself how can I make it lighter.
Edited by Rob H on 22nd Apr, 2010.
i reckon you can get 5kg out off the engine block without drastic work, and i know of someone(no name :)) has already done similar to the box
swap out the front subframe with a cheese grater aswell
Advantage
Member #: 1450
Near Paris - France
145 tyres ?
Rusty by nature
Laurence
Member #: 8258
Fit an aluminium head.
Fit a shorter exhaust system which exits at side of car.
Fit alloy wheels.
Fit a smaller petrol tank/only ever part fill petrol tank.
I wouldn't remove the bracing from the bonnet, as the edges tend to flare out and catch the wings. You're better off fitting a fibreglass bonnet.
AWDmoke
Member #: 713
Western Australia
[quote=J1380 engine because there is less material in the block ? *happy* [/quote]
824g saved there alone.
Denso alternator, drilled subframes, grind off unecessary metal off box/block/hubs etc. There is a great range of cheap ways to reduce mass on this site if you search.
On 24th Dec, 2008 Nic said:
best_stig
Member #: 6449
Brisbane, Australia
Sand blast it to bare metal, cover it in salt and leave outside for a few months, the. get it sand blasted again.
In boost we trust
AWDmoke
Member #: 713
Western Australia
Ah, the secret recipe for HRM
(Honeycombe Racing Metal)
I already have some of that.
Edited by AWDmoke on 23rd Apr, 2010.
5kgs off the gearbox? No way!
