| Home > Help Needed / General Tech Chat > No Spark | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
26th Jan, 2005 at 04:19:28pm
Need some advice lads! I had my turbo running but i took it a part to try and fit my intercooler. I didn't bother in the end and i put it all back together and it won't start!! |
26th Jan, 2005 at 07:11:49pm
firstly NEVER DESPAIR you get bad days and more bad days Edited by BENROSS on 26th Jan, 2005.
26th Jan, 2005 at 08:57:23pm
What did you remove when you tried to fit the intercooler... might give us a clue :) |
26th Jan, 2005 at 11:57:24pm
i took the coil off and thats it! i also took the wires off the modual and now i can't remenber which way round they go and i just guessed and i think i might of blown some thing cos it used to work i thought i might of done in the modual so i went and got a new one and it wasn't that!! i also put all new leads and plugs and i also swaped the coil i've got it right i think i've got it right i think i've got one wire going from the modual to the + and one to - but can anyone tell me for shore which one is which do you think the dizzy its self is bust cos i can't think of anything else cos everythings so basic |
27th Jan, 2005 at 12:42:39am
print out this tread and take it into the garage and follow what i said carefully!!!!!
![]() 439 Posts Member #: 176 Pre-op Transvestite Felixstowe, Suffolk |
27th Jan, 2005 at 10:12:43am
i always find its best to work backwards ... start by seeing if the plugs are sparking, if not then test the leads, if there is no power there check the dizzy cap, if that is fine try a different dizzy, if that is fine check your earth connection, etc etc etc, just keep working backwards till you find the source of the problem NO LONGER A <3 lover of BOLT-ON plastic <3 .... (and DOUBLE proud of it) |
27th Jan, 2005 at 07:34:55pm
i thanx lads i think its the dizzy but i can't work out how its happened cos the dizzy is new and i still don't know which way round the wires go |
28th Jan, 2005 at 01:16:07pm
the piggy backed wire live from the coil to the dizzy mod needs to be on to the top terminal on the dizzy mod
28th Jan, 2005 at 11:28:37pm
thanx big help!! can't see any tread you mean though? quick questionfor you what would happen if you had put the round the wrong way what could it blow?? or would it just not work? |
28th Jan, 2005 at 11:47:57pm
wont hurt a thing if you get a wire wrong on the mod, "i assure you.
Edited by BENROSS on 28th Jan, 2005.
1st Feb, 2005 at 10:26:23pm
sorry silly me! Well i've sent the dizzy back to avonbar for them to look at cause i really don't know what else it could be
1st Feb, 2005 at 10:37:57pm
let us know ?
4th Feb, 2005 at 11:31:01pm
HATEING MY LIFE!!!!!!!!!!!
5th Feb, 2005 at 01:14:57am
DONT DESPAIR
5th Feb, 2005 at 10:39:42am
thanx it means alot mate but i@ve got to wait to avonbar post my dizzy back should be all go next weekend well me all go not the car! all i can say is thank god for the golf i brought! its a shed must least it runs i want to get it down the psint shop but it can@t even make the two miles there lol |
5th Feb, 2005 at 12:17:57pm
have you got 12v going to the coil? you need to run it from the fuse box or similar to the + side,
5th Feb, 2005 at 12:33:01pm
no worries
5th Feb, 2005 at 03:07:55pm
Where would i be without you lads! Oh yeah still in the garage scraching my head! |
![]() 127 Posts Member #: 439 Advanced Member derbyshire |
6th Feb, 2005 at 09:58:30am
white with pink stripe to positive on coil, white with black stripe to -, from the module white to + and white with black stripe to-, theres also another feed to + on the coil from the loom but i cant remember that. leave your ignition on and your coil should get hot after 5 minutes or so if its wired up correct. hope this helps. Edited by miniman on 6th Feb, 2005.
6th Feb, 2005 at 12:42:57pm
zeemax pm sent buddy
6th Feb, 2005 at 09:04:44pm
to test why not run a wire directly from the + on the battery to the + on the coil and wire a cable from the - on the coil to a bolt on the engine or bodywork. This will make the coil permenantly live - do not leave it direct to the battery!
6th Feb, 2005 at 09:11:48pm
I forgot to mention the wires on the dissy.
7th Feb, 2005 at 11:25:52am
excellent description sumpnut
7th Feb, 2005 at 11:19:37pm
I should be typing out coursework, but I would rather be typing mini related stuff on here to be perfectly honest! |
8th Feb, 2005 at 05:18:10pm
i was the same as you over 30 years ago
!! I can't seem to get a spark!! I've tryed everything and i was wondering does anyone have any ideas or is there a conman thing that can go? theres power at the coil and power at the plug of the dizzy and i've even swoped a coil off my mate mini and it still don't work any help do be a life saver!
