| Home > Technical Chat > Nissan Pulsar GT28 turbo | |||||||
![]() 39 Posts Member #: 8850 Member |
25th Apr, 2010 at 05:35:52pm
Does anyone have any opinions on this turbo? I have herd it could be a good choice for a 1275 build that im looking into doing, however after a search i carnt find anything.
25th Apr, 2010 at 06:12:11pm
It may be a bit on the large side. Depends on the exhaust housing size anything bigger than a .49 and it will never spool. The cold side is usually a .42 cover with a 60 trim wheel again which maybe on the large size depending on your application. IMO the rs turbo t3 or a more modern turbo would be a better option. |
25th Apr, 2010 at 07:17:28pm
bit big,
25th Apr, 2010 at 07:21:49pm
Ahh i see, i had been told it was slightly smaller than the T3, yet larger than the T2, however considering its from a 2.0 engine i guess that would make sence.
25th Apr, 2010 at 07:31:26pm
I have one on my R5 it starts to think abou making boost at 4000rpm and then full boost by about 4600rpm. |
3596 Posts Member #: 655 Post Whore Northern Ireland |
25th Apr, 2010 at 09:46:27pm
It would probably work fine. Its a T25 flange with a semi-small housing...cant rem what size.
25th Apr, 2010 at 10:32:03pm
Im looking for about 170 - 180 bhp so i dotnt think i really need to do anything unsual with the setup, a 1293 with a low Cr and intercooler running a T3 should be enough to achive those goals shouldnt it?
25th Apr, 2010 at 11:31:33pm
lol i use one, get full boost on the 1400cc bottom end at 5500rpm.. i would go for something smaller on an a-series imho.
Edited by evolotion on 25th Apr, 2010. turbo 16v k-series 11.9@118.9 :)
25th Apr, 2010 at 11:35:35pm
easy mate especially if you use a .36 escort exh wheel always looking for them bigger bunches of bannanas |
26th Apr, 2010 at 01:16:23pm
On 25th Apr, 2010 evolotion said:
lol i use one, get full boost on the 1400cc bottom end at 5500rpm.. i would go for something smaller on an a-series imho. exhaust housing is .86 it is a big turbo You sure its the same one ?? I had a shitty old Cossie based T3 on my 1293, and it made full boost ( 22psi ) at 4500rpm with a 0.36 turbine housing. The T28 with the smaller T25 flange and similar compressor should spool much earlier. Or is the GTIR GT28 vastly different that that on the 200sx ? 9.85 @ 145mph
26th Apr, 2010 at 02:10:30pm
On 25th Apr, 2010 Rich. said:
Im looking for about 170 - 180 bhp so i dotnt think i really need to do anything unsual with the setup, a 1293 with a low Cr and intercooler running a T3 should be enough to achive those goals shouldnt it? Rich good luck... you will need to put allot more thought in than what you have detailed above, then maybe at 20 psi + and don’t expect it to be driveable on the road or last long between rebuilds. |
26th Apr, 2010 at 06:02:45pm
In which case could you shead some light for me? I was origionaly going to turbo a 1275 engine but have been offered a metro turbo lump for decent money. I was thinking along the lines of 1293 with 18cc dished pistons, head work done, avonbar camshaft, decent size intercooler and dump valve, then crank the boost upto 15 to 20 psi. Although i have been now looking into the GT17 turbo as a replacement. Its going to be for a fast road, but still a daily driver!
Edited by Rich. on 26th Apr, 2010. |
26th Apr, 2010 at 06:56:57pm
for a daily driver i would stick to 120 / 140 at the most and say 10 psi.
Edited by MarkGTT on 26th Apr, 2010. |
26th Apr, 2010 at 08:01:30pm
lol i use one, get full boost on the 1400cc bottom end at 5500rpm.. i would go for something smaller on an a-series imho. exhaust housing is .86 it is a big turbo You sure its the same one ?? I had a shitty old Cossie based T3 on my 1293, and it made full boost ( 22psi ) at 4500rpm with a 0.36 turbine housing. The T28 with the smaller T25 flange and similar compressor should spool much earlier. Or is the GTIR GT28 vastly different that that on the 200sx ? yeah exhaust side is huge, compresors the same though, the turbine eats right into the flange area, its as big as you can get in that frame, i tried a SR20 200sx (s14, non ball bearing) turbo and boost came in over 1000rpm sooner(0.64 ish turbine), and never had the top end the pulsar turbo did. I just cant see one spooling on an a-series tbo not within any reasonable powerband on your average 5port. turbo 16v k-series 11.9@118.9 :)
26th Apr, 2010 at 08:06:27pm
On 26th Apr, 2010 MarkGTT said:
for a daily driver i would stick to 120 / 140 at the most and say 10 psi. You dont really need 18cc in the piston and a well worked head unless you intend to run massive boost. Cam is a good choice and a GT17 seems to be the turbo of choice atm. with this kind of power you need to start thinking about mappable ignition too, have a good read on this site there are some great post designed for new members. Thats brilliant thanks, however wouldi not be able to build up the engine like that then have an in car boost controller, so say 10psi when driving about then whack it upto 15 or 20 for trackday use? Rich EDIT; Something like this; http://www.turbosmartonline.co.uk/?gclid=C...CFY-X2AodlDd9vw Edited by Rich. on 26th Apr, 2010. |
26th Apr, 2010 at 08:36:07pm
yeah you can do, but the lower the CR the more slugish the car will be off boost so not ideal for a daily - but i guess its a good compromise. This is how i use mine (10 psi for road and track 18 psi for the quarter mile) but i dont use it for the daily commute works well for a fun weekend car.
26th Apr, 2010 at 08:50:44pm
Im in Newcastle, that would be perfect. I have a guy that works on the same bussiness park that my dads company is based, and he specialises in mini resorations, which is where im looking at getting my metro from. He has a Metro Turbo, with some modifications to the engine, producing 153 break, but unfortunatly its not road legal yet so i could have a drive, but if theres anyone local running a turbo mini i would apriciate it massivly!
204 Posts Member #: 5022 Senior Member Oxford, Kings Lynn, Pod, Pub. |
26th Apr, 2010 at 09:17:16pm
The Pulsar turbo is far better suited for say a 1.6, 1.8, 2.0. Got A GTM With A Honda In the Back, and huge Nitrous bottle where the passenger seat should be when racing!
On 19th Oct, 2009 Nic said:
Ill donate to the cause if you can make it do wheelies!! |
