Home > Help Needed / General Tech Chat > metro hydraulic clutch biting point too low
mayoturbo
Member #: 1395
chepstow
The biting point on my metro is right on the floor. I am 99% sure there is no air in the system. It has a verto clutch, with the verto clutch system and the hydraulic damper. Both the cylinders are old but the damper and braided hose is new.
Any ideas? thanks
mayoturbo
Member #: 1395
chepstow
Anyone?
I had a similar problem, it was my slave cylinder that was knackered.
steve1275
Member #: 951
Bromsgrove
Check out the length of the slave cyl. pushrod,you can lengthen this.Also look for wear in the mechanical bits -clevis pins at clutch master cyl.etc.The Midget suffered from this.
'Where does the engine go?'
