| Home > Help Needed / General Tech Chat > thread of the master/clutch cilinder | |||||||
282 Posts Member #: 1404 Senior Member The Netherlands |
27th Apr, 2010 at 08:17:48pm
Hello,
there is nothing wrong with a A-series that a turbo can't fix.
27th Apr, 2010 at 08:46:27pm
So far as i'm aware (and others may correct me) everything is 3/8" UNF EXCEPT the yellow tag master cylinder which is M10 and M12 (both metric fine thread).
28th Apr, 2010 at 12:07:49am
Although I certainly would want long runs of braided hose for such important things like brakes.
28th Apr, 2010 at 11:15:22am
lots of people seem to feel that way steve, and can understand why in my head, but i bought a full brake set up off a miglia a few years back, which had 100% braided lines, its on my car now, and my brakes are spot on, the lines dont try to snake or flex at all when under pressure? "Turbo's make torque, and torque makes fun"
28th Apr, 2010 at 12:59:38pm
flex is one aspect, and as you say probably not an issue, as the hose rating likely exceeds any pressures it will ever see.
28th Apr, 2010 at 02:11:10pm
On 28th Apr, 2010 stevieturbo said:
Not even sure if it would be an MOT issue having flexibles througout ? if they cant see it they cant fail it, run the flexis hidden but have the solid under the car front to rear but then again im with you id have solid pipes where possible edit: broken quote Edited by Brett on 28th Apr, 2010. Yes i moved to the darkside |
28th Apr, 2010 at 02:27:09pm
No issue for MOT, I've been MOT'ing a car with braided lines throughout for years.
28th Apr, 2010 at 03:38:21pm
that and we dont have mot's over here helps lol
29th Apr, 2010 at 11:30:07am
On 28th Apr, 2010 joeybaby83 said:
lots of people seem to feel that way steve, and can understand why in my head, but i bought a full brake set up off a miglia a few years back, which had 100% braided lines, its on my car now, and my brakes are spot on, the lines dont try to snake or flex at all when under pressure? Is this a kit or made for the car? Piccie possible
I don't see a real problem with braided hoses. There are on many motorcycles with no problems. I can order them but they need to know which size bolts i need through the banjo. Lenght wise it up to what i want
29th Apr, 2010 at 07:58:46pm
it was a 2nd custom set up of a mig, will try and dig some out for you "Turbo's make torque, and torque makes fun"
30th Apr, 2010 at 08:32:57am
On 29th Apr, 2010 joeybaby83 said:
it was a 2nd custom set up of a mig, will try and dig some out for you Thanx, i try to get more information from my friend, Google
