| Home > Help Needed / General Tech Chat > Idler gear and HP/RPM | |||||||
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
27th Apr, 2010 at 10:33:26pm
Hi!
Edited by Asphalt on 27th Apr, 2010. [X] nail here for new monitor |
27th Apr, 2010 at 10:46:03pm
you can block the oil pressure relief valve, and divert the oil to above the primary, i think harry tried pressure feeding the idler bearings a few years back, but has since completely re-engineered it, terry is trying replacing the thrusts with radial roller bearings, and there is someone else im missing, but cant remember who?
27th Apr, 2010 at 10:51:06pm
http://www.turbominis.co.uk/forums/index.p...tid=248104&fr=0 On 7th Oct, 2010 5haneJ said:
3596 Posts Member #: 655 Post Whore Northern Ireland |
28th Apr, 2010 at 12:06:49am
pin the thrusts to stop them spinning ???
28th Apr, 2010 at 01:21:25am
On 27th Apr, 2010 minimole23 said:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=248104&fr=0 Thanks! Impressive thread! Spend the last few hours reading it. That's any question awnsered. And a lot of my thoughts about side loadings etc. corrected!! :) THANKS TM!! :) Cheers, Jan Edited by Asphalt on 28th Apr, 2010. [X] nail here for new monitor |
72 Posts Member #: 6792 Advanced Member |
28th Apr, 2010 at 10:02:22am
(Stupid laptop - see one down) Edited by mowog on 28th Apr, 2010. |
28th Apr, 2010 at 10:02:34am
Hi Jan,
28th Apr, 2010 at 10:46:59am
On 28th Apr, 2010 mowog said:
Hi Jan, The usual approach to this is a bit of a different set up. It uses a fixed shaft and tapered roller bearings in the gear itself. Fairly simply and highly effective (I've never heard of one of these giving any trouble). Cheers On 17th Feb, 2009 Rob H said:
28th Apr, 2010 at 10:58:54am
i think hes referring to the usual timpken type paul "Turbo's make torque, and torque makes fun"
28th Apr, 2010 at 11:27:13am
http://www.med-engineering.co.uk/product_d...86&vlang_id=130
28th Apr, 2010 at 12:26:37pm
Does the MED Roller idler come with the staples too? On 26th Oct, 2004 TurboDave16v said:
28th Apr, 2010 at 12:48:13pm
But the MED setup is a Roller Bearing Mowog seems to be refering to some kind of gear with a number of Tapered Roller bearings!! in the gear
fixed shaft and tapered roller bearings in the gear itself. On 17th Feb, 2009 Rob H said:
28th Apr, 2010 at 01:18:51pm
On 28th Apr, 2010 Sprocket said:
Does the MED Roller idler come with the staples too? Keen eye there Colin. I wondered WTF you were on about to start with. If something is worth doing, it's worth doing half of. |
28th Apr, 2010 at 02:06:11pm
What is this better than two roller bearings as standard? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
28th Apr, 2010 at 02:54:41pm
Hi Jan, The usual approach to this is a bit of a different set up. It uses a fixed shaft and tapered roller bearings in the gear itself. Fairly simply and highly effective (I've never heard of one of these giving any trouble). Cheers Sounds interesting! Basicaly an adoption of the wheel bearings layout to the idler gear? Cheers, Jan [X] nail here for new monitor |
28th Apr, 2010 at 03:25:11pm
thats how the jkd roller idler has always been hasnt it?
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
28th Apr, 2010 at 06:21:00pm
Something like this ?
28th Apr, 2010 at 08:55:42pm
yarp "Turbo's make torque, and torque makes fun"
28th Apr, 2010 at 10:51:58pm
Hi Jan, The usual approach to this is a bit of a different set up. It uses a fixed shaft and tapered roller bearings in the gear itself. Fairly simply and highly effective (I've never heard of one of these giving any trouble). Cheers Sounds interesting! Basicaly an adoption of the wheel bearings layout to the idler gear? Cheers, Jan Yeah, much like that but not quite like those above, except that pinyandnobrain has put up, I think that's a JKD version but straight cut. We do our own using the helicals and two taper rollers for street use. I am not sure if anyone has these 'off the shelf' these days, but I think someone did do them at one time. With the pre-A+ stuff, we do it when we get around the 85 - 90 Fly HP mark and for A+ around the 100 - 105 HP. Edited by mowog on 28th Apr, 2010. |
29th Apr, 2010 at 12:16:37am
With the pre-A+ stuff, we do it when we get around the 85 - 90 Fly HP mark and for A+ around the 100 - 105 HP. Seems a bit of a waste to me. I have run standard helicals with 100lbft and im sure Robert is still running standard helicals with 180lbft. Now lets be honest, its the torque that really matters
29th Apr, 2010 at 12:31:42am
I really would love to see a pic of that mowog sounds very intresting ? On 17th Feb, 2009 Rob H said:
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
29th Apr, 2010 at 01:38:07am
O/T
29th Apr, 2010 at 09:14:54am
On 29th Apr, 2010 1972-ANGUS said:
O/T Out of interest, is 24/30/24 = 1:1? Yeap. |
29th Apr, 2010 at 09:22:06am
On 29th Apr, 2010 PaulH said:
I really would love to see a pic of that mowog sounds very intresting ? I'll see if I can dig one up, but it's not a lot different to that shown by pinyandnobrain above, only helical. |
![]() 6753 Posts Member #: 828 Post Whore uranus |
29th Apr, 2010 at 01:02:28pm
id say up around 200 to 210 lbs/ft with the intercooler working colin.
