Home > Beginners Tech > Fuel Regulator
Mad Max
Member #: 8442
Maldon, Essex
Hello TMers,
Just after a bit of advice really, i have trailed through lots of search results so if this has already been discussed i apologise but it must be fairly well hidden.
Just wondered if there is a particular reason why nobody used these regulators that are all over flebay.
http://cgi.ebay.co.uk/Fuel-Pressure-Regula...399010820668842
It seems to cheap to be any good. So if someone could just clarify. :)
They are for fuel injection and run at 3 bar pressure. They also control the upstream pressure rather than provide a controlled outlet pressure.
So not the correct kind for an SU.
I've used that type with my fuel injection and it failed in a short time.
Mad Max
Member #: 8442
Maldon, Essex
Thanks for the fast reply, you pretty much cleared that issue up, will get the standard one then.
