| Home > Help Needed / General Tech Chat > Idle Air Control Valve | |||||||
28 Posts Member #: 1503 Member Long Island, New York, USA |
30th Apr, 2010 at 01:17:11pm
30th Apr, 2010 at 01:19:32pm
Depends entirely open the capabilities of the Canems ECU.
30th Apr, 2010 at 03:20:14pm
Its a PWM valve On 26th Oct, 2004 TurboDave16v said:
1st May, 2010 at 12:16:39am
Thanks I've just been advised to use the GM unit which the Canems can operate. |
1st May, 2010 at 03:52:45pm
How will an idle valve stop your foot getting tired ? 9.85 @ 145mph
2nd May, 2010 at 01:31:00pm
Won't have to keep blipping the throttle when the engine is idling :) |
2nd May, 2010 at 01:38:29pm
Why not either adjust the idle ignition advance, or adjust the throttle stop? Edited by Sprocket on 2nd May, 2010. On 26th Oct, 2004 TurboDave16v said:
2nd May, 2010 at 03:44:00pm
On 2nd May, 2010 minimized said:
Won't have to keep blipping the throttle when the engine is idling :) Get the problem fixed so that it will idle then. It must either have a bad fault or be very badly tuned if it wont idle on its own. 9.85 @ 145mph
