Home > Help Needed / General Tech Chat > Can not fined where to buy this screw! HELP
chominsh
Member #: 8160
, mitcham, surrey, london, cr4
Hi there!
I really need help with buying (not sure about right name of part) screw which goes between oil pressure adaptor and oil pressure switch!
You can see this screw on pic :
It is from mini metro turbo engine.
I spend all day looking for it in all local garages and shops and no one have it and knows where to get it :(
Maybe anyone have it? or any solution to this?
This is my daily car so I need it as soon as possible :(
Nothing special!
chominsh
Member #: 8160
may be someone knows at least correct name for this part!!
Thank you for help :)
Nothing special!
5portsrock
Member #: 2023
nr Portsmouth ,Hampshire
The item is called a Banjo bolt . I would try one of the minishops who sell 2nd parts
It's a banjo bolt but not a normal one (because of the extra thread in the head of the bolt and the oversize head) - typical of Leyland to make things difficult.
There are other ways of connecting the turbo oil feed and the pressure switch (or gauge) at the front of the block, ie, Avobar sell a kit or just the fittings for the more modern braided oil feed pipe but I assume yours is the original metal one ???
TBH I'd put a (better) photo in the wanted section as someone who has changed to the more modern fittings may have a second hand one left over from an original Metro Turbo setup.
What's wrong with it anyway ???
you could drill and tap a standard bolt from the oil filter head to gallery pipe
chominsh
Member #: 8160
yea, it is bit different :(
yes i have original one (metal), i am thinking now how to fix it till Tuesday *happy*
Is there goes high pressure? do rubber pipe will hold it?
look what is wrong with it!
*happy**happy**happy*
basically, i do not need that switch i just want to make it work again, some how to connect it to gather with adopter :)
[quote=Rod S,1st May, 2010]It's a banjo bolt but not a normal one (because of the extra thread in the head of the bolt and the oversize head) - typical of Leyland to make things difficult.
Nothing special!
Anything you can do to get rid of the factory steel oil feed...is a wise investment.
chominsh
Member #: 8160
thank You for advice!
i made one bolt for now :) but it still little bit leaking :(
at least it is working for now :)
any advice what is better to buy instead this factory one?
Nothing special!
get a braided hose made up and T into the oil pressure switch hole on the front of the block. worked well on our van, all be it briefly...
chominsh
Member #: 8160
what about turbo? is it will be ok there?
yea i should look for something better :)
Nothing special!
The braided hoses have a "plastic" internal liner so although the outside is all stainless, they must not touch (or be too close to) any of the hot parts of the turbo or manifold.
But the ones specifically made for the A series (Metro setup) are long enough to be able to swing them in a loop in front of the turbo (engine side) keeping them well clear. If you get one made at a local hydraulic place just make sure it's long enough to do the same.
This is how ours runs:
Ell
Member #: 8439
Romiley
what is the air filter you got on your carb pal?
On 27th Apr, 2010 wolfie said:
and some chav will nick it to fit on there rat look saxo
Ell
Member #: 8439
Romiley
edit: double post
Edited by Ell on 2nd May, 2010.
Would a brake banjo bolt work? they are the same thread, although the head is smaller.
The air filter is just a K&N from minispares I believe
chominsh
Member #: 8160
Looks good!
need to make something similar :)
Thank You for help
Nothing special!
