Home > Help Needed / General Tech Chat > Bleedin' brakes!!
bawbee
Member #: 191
Falkirk, Scotland.
I am having a pig of a time trying to get my brakes properly bled. I am running 4 pots with a Cooper servo unit. This is a front/rear split system with a pressure reducer valve in the rear section. The pedal pumps up ok and holds firm, but is very spongey if not pumped. Anyone else had similar problems??*tired*
turbosteve
Member #: 370
Reads "my mates" max power whilst wearing my Mrs's underwear
Have you tried a pressure bleeder on it ? i bought a gunsons one ?20 plugs into the tyre valve it did the job for me
Always an arse of a job.
If it pumps up then holds steady then it's just air in the system.
I generally find it takes longer than you think to get all the air out of the rears, so bleed them some more.
wil
