Home > Help Needed / General Tech Chat > How do you run you're fuel lines
paneermeel
Member #: 1404
The Netherlands
Hello all,
the 1000cc engine is out, and the 1275 turbo is going in*happy* Ans the first "problem" is............
I was planing on running the fuel lines under the car but i don't really know how to get them from the unterside to the regulator at the bulkhead. The copper one runs through a small space between the sub and the car. But i don feel safe putting the much bigger lines through there. Has anyine a good picture of how he did it on his car?
Gegroet :)
there is nothing wrong with a A-series that a turbo can't fix.
www.turbomini.nl
MarkGTT
Member #: 1194
Shropshire.
I run mine internally.
Part way down page 12
http://www.turbominis.co.uk/forums/index.p...d=249927&fr=275
They are easy to fit (in the gaps) ie, there is plenty of room, the pain I had was bending them to make them fit if that makes sense.
paneermeel
Member #: 1404
The Netherlands
thanx for the replies. *Clapping*
But i notice that i forgot something.......*blush*
I was planning to use braided hoses from the tank to the engine bay, so the od of the fuel lines are greater then the copper lines Rod S used.
@MarkGTT: where did you let the fuel lines enter the enginebay?
Gegroet Jochen *happy*
www.turbomini.nl
MarkGTT
Member #: 1194
Shropshire.
lower bulkhead, then they enter the engine bay just behind the back of the subframe - takes some time to get the bends right but it works well.
