| Home > Technical Chat > Servo removal | |||||||
![]() 539 Posts Member #: 6807 Post Whore York |
3rd May, 2010 at 09:25:00pm
I have a 1990 mini with the standard '88 on servo master cylinder (green band), front to rear split lines, and the standard PDWA valve.
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
3rd May, 2010 at 09:31:53pm
Hi Andrew,
3rd May, 2010 at 09:42:35pm
Does the whole pedal box need changing or just the actual pedal itself? I haven't got one to hand at the momment so i can't check Edited by adcyork on 3rd May, 2010. |
3rd May, 2010 at 10:23:23pm
I'm not aware of anyone ever having just changed the pedal, but it's probably possible. Chances are though, that you're more likely to be able to pick up a complete non-servo pedal box than just the brake pedal alone.
3rd May, 2010 at 10:37:29pm
Yea that was my thoughts too, i was just going to remove the pedal, weld then re-drill, or alternatively weld a sleeve in the hole.
4th May, 2010 at 12:03:18am
I used the yellow tag master without any issues. I replaced just the pedal as well.
Edited by Sprocket on 4th May, 2010. On 26th Oct, 2004 TurboDave16v said:
