Home > Help Needed / General Tech Chat > Help, engine cutting out after bursts of speed!!
Barrythebodger
Member #: 5062
Herts
hi all,
I'm having an issue with the wifes '89 mini that has been fitted with a 1275 and stage 1 kit (not a turbo, yet!)
It was running fine but has now started to cut out. it only happens when you ease off the accelerator after short bursts of speed and does it in any gear. The engine starts up again if you push the pedal down again and will return to normal if you hold the revs at around 2-3000rpm
any ideas?
thanks
mine is doing this, my wbo2 says way too lean, i had to wind the fuel down 2 turns for the mot, and im currently playing with needles
I had problems with my old clumban dieing when the engine/under bonnet was really hot (i.e. after a thrashing) I think it was a dodgy plug lead. I replaced all the ignition bar the leads and it didn't fix it. A set of new descent leads later and it never happened again.
Johnny
Member #: 6926
Accrington
it could be a loose wire to the coil or something along this thought, as my turbo used to misfire BADLY when under ONLY BOOST but then completely konked out 2 days later, first thing i did when i started troubleshooting was check the ignition system and i found that my +12v to coil had corroded off...
Bman
Member #: 5647
swindon wiltshire
when mine did this it turned ut to be the vaccum hose on the side of the carb had come off..would literally run fine until you accelerated alittle harder then came off the pedal..or if holidng it slightly higher revs (3k upwards.) just a thought
Barrythebodger
Member #: 5062
Herts
thanks guys, i'll check out all your suggestions this weekend.
