Home > Help Needed / General Tech Chat > SAW and PIP shielded cables
jonb_5
Member #: 3193
Torbay, Devon
Hi
I am going to make sure the SAW and PIP cables on my megajolt are shielded.
Do they have to be shielded from one another or iirc it is a 2 core sheilded cable?
If so I will justrun two lengths of the 2 core cable and use 1 core in each if you get what i mean.
Thanks
Jon
One 2-core shielded cable is what you want. Make sure you only earth the shield at one end.
I used shielded microphone cable on the van, worked a treat and was fairly cheep.
