Home > General Chat > Front Brake Disc choice ?
Doodmeister
Member #: 149
Alberta, Canada
Hi.
I'm currently running STD vented turbo discs which are getting old so I need to replace them what?s the best choice EBC, Pagid or any other? Also Drilled, Grooved or both??
Karl.
t3gav
Member #: 229
Gavin@minispares.com
kent
i'm doing the same thing at the mo, all i can suggest is you don't need 16 grooves as all they do is take the glaze off the pads so 4 will do, you probably wont even need them drilled if they're vented.
Skinns46
Member #: 165
Cambridge
Pagid 8 Groove are good. I've turned down these to give me 7.9" and i'm useing KAD 4 pots under 10's.
http://photobucket.com/albums/y139/Skinns46/
SumpNut
Member #: 28
I have read any more than 4 groves is just a waste of surface area.
I belive ebc do some disks with "dimples" rather than drilled holes - so smaller disks can have the benifits but not the loss of strength assosiated with drilled holes.
