| Home > General Chat > k100 / k1100 | |||||||
6th May, 2010 at 04:52:41pm
i seem to remember a thread where the 2 heads was compared pro/cons, any one point me in the right direction i cant find it
Yes i moved to the darkside |
6th May, 2010 at 08:30:34pm
The head itself could be the same...K100 is often assumed to be a 8 V head, but my head for example is a K100RS 4v head, which is a 16Valver.
6th May, 2010 at 09:39:22pm
cheers, i just assumed the k100 = 8v and k1100 = 16v Yes i moved to the darkside |
7th May, 2010 at 06:28:18am
or one efiminis maybe? there is info about them there at least |
7th May, 2010 at 11:46:30am
i thought it was k100 is 8v and 11 is 16v the k100rs is still a 8v head not 16 acording to egay and bmw forums Drives
7th May, 2010 at 12:04:12pm
you are wrong
Edited by miniminor63 on 7th May, 2010. |
7th May, 2010 at 12:23:09pm
Edited by Paul R on 7th May, 2010. Drives
7th May, 2010 at 12:28:00pm
On 7th May, 2010 miniminor63 said:
you are wrong Take this as an example: ![]() ![]() now im confused even more, my head looks like that, its apparently a k100 8v Yes i moved to the darkside |
7th May, 2010 at 12:28:08pm
On 7th May, 2010 Paul R said:
i thought it was k100 is 8v and 11 is 16v the k100rs is still a 8v head not 16 acording to egay and bmw forums 1989 the 16v head was introduced which was called the K100RS 4v, and the K1 On 26th Oct, 2004 TurboDave16v said:
7th May, 2010 at 12:32:42pm
you are wrong Take this as an example: ![]() ![]() now im confused even more, my head looks like that, its apparently a k100 8v If all the cam cover fixing bolts are directly oposite each other, its a 16v if they are off set, its an 8v. This was the one thing that showed up that 999 engine, all over Youtube, as an 8v, anounced as 16v On 26th Oct, 2004 TurboDave16v said:
7th May, 2010 at 12:37:40pm
http://www.flyingbrick.de/GB/types.html On 26th Oct, 2004 TurboDave16v said:
7th May, 2010 at 12:49:17pm
so both right or what im confused idk what im ment to look for now Drives
7th May, 2010 at 12:50:38pm
I have been right all the time. I state in my first post that there is both a 8V and a 16V K100 |
7th May, 2010 at 12:58:07pm
right i see what the pics are pointing out now, mine is same as the top pic, but definitely is 8v so that makes it a k100 8v... Yes i moved to the darkside |
7th May, 2010 at 01:05:37pm
It cannot be 8v if all the cam cover bolts are oposite each other, like the top pic.
7th May, 2010 at 01:34:13pm
the bolts will be staggered then, i never took pictures before storing it in the loft Yes i moved to the darkside |
