Home > Technical Chat > 8.4" AP caliper half retaining bolt torque
adcyork
Member #: 6807
York
just in the middle of rebuilding an 8.4" AP caliper.
Does anyone know what torque value the bolts that hold the two caliper halves together should be done up to?
Thanks
Good luck, as when I did this years ago I could not find the torque setting anywhere. AP will not tell you either.
I settled for 52Nm as this is the torque for the caliper bolts to the hub- both are the same thread size, both are threading in to cast iron.
Adam_R
Member #: 1938
near Dundee
ive had a look in the "proper" manuals (the ones garages have ) and i dosent tell you either
