| Home > General Chat > thrust measuring | |||||||
614 Posts Member #: 2153 Post Whore kings langley |
9th May, 2010 at 03:06:56pm
hi i'm just setting the end float on the crank and fairly new to this... i've searched and i'm aiming for around 0.006mm? but i'm getting strange readings from my dial gauge
9th May, 2010 at 03:26:49pm
do you mean .06mm?
9th May, 2010 at 03:34:39pm
oooops too many 0's so i lever, remove screwdriver then take reading?
9th May, 2010 at 05:18:49pm
Don't use a screwdriver. Use your hands only. With a screwdriver you can get sufficient leverage to make the clearence what you want.
