| Home > Technical Chat > Engine build | |||||||
14 Posts Member #: 987 Member |
9th May, 2010 at 03:45:47pm
Hi. Rebuilding my engine. Going to have the head ported and the chambers opened up. Will i see any real significant gains by puting a better cam in and if so any good ones to recomend. Minispeed is down the road from me and they have a "phase 2" in stock. My gearbox is standard and in very good condition. Any ideas what kind of bhp they will take? Also i have an oil cooler but have seen loads of turbo'd minis not running with them so is it needed. Edited by stace on 10th May, 2010. |
549 Posts Member #: 5327 Post Whore Dudley, West mids |
9th May, 2010 at 07:53:56pm
b |
603 Posts Member #: 1938 Post Whore near Dundee |
9th May, 2010 at 08:04:47pm
c |
9th May, 2010 at 08:09:14pm
d On 28th Aug, 2011 Kean said:
9th May, 2010 at 08:10:06pm
The person that says E will get my cock in there ear Crystal Sound Audio said:
![]() 116 Posts Member #: 4273 Advanced Member stoke on trent |
9th May, 2010 at 08:36:35pm
f |
9th May, 2010 at 08:38:11pm
thought tmf was back up and running... turbo 16v k-series 11.9@118.9 :)
9th May, 2010 at 10:16:19pm
On 9th May, 2010 stace said:
Hi. Rebuilding my engine. Going to have the head ported and the chambers opened up. Will i see any real significant gains by puting a cam in and if so any good ones to recomend. Minispeed is down the road from me and they have a "phase 2" in stock. My gearbox is standard and in very good condition. Any ideas what kind of bhp they will take? Also i have an oil cooler but have seen loads of turbo'd minis not running with them so is it needed. cam = definately see gains its the torque that kills a box, 100ftlbs will do a box over in no time if you drive like a twat, if you search its been done to death ( the question and the boxes) if your oil overheats put an oil cooler on it, if it doesnt overheat you dont need one Yes i moved to the darkside |
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
10th May, 2010 at 12:30:18am
Will i see any real significant gains by puting a cam in and if so any good ones to recomend. Id recommend putting one in you will definately see gains. To decide the correct one for you, your best bet would be to use the search button at the top. |
10th May, 2010 at 07:27:44am
i find putting a cam in helps significantly, otherwise it could be a non starter |
10th May, 2010 at 09:11:46pm
now that was funny.
On 9th May, 2010 nibble36 said:
f I run a supercharger and I don't care the TB is on the wrong side.
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
11th May, 2010 at 01:40:54am
f
cheered me right up |
11th May, 2010 at 07:42:18am
On 10th May, 2010 philc said:
i find putting a cam in helps significantly, otherwise it could be a non starter It does however depend on where you put it.... On 13th Jul, 2012 Ben H said:
11th May, 2010 at 11:10:16pm
i find putting a cam in helps significantly, otherwise it could be a non starter It does however depend on where you put it.... I run a supercharger and I don't care the TB is on the wrong side.
