Home > Technical Chat > Crank nose size
adcyork
Member #: 6807
York
Could anyone tell me the exact size of the crank nose that the bottom pulley fits on to please?
I need to make a shaft on which the pulley will sit so that it can be balanced at the machinists.
Thanks
one inch dia,
Thanks
You use the crank as a shaft *wink* Balance the crank first, then add the damper/pulley.
adcyork
Member #: 6807
York
The pulley is to be fitted to a fully built engine so that isn't possible
Nah, I don't believe you *wink*
adcyork
Member #: 6807
York
I had the pulley balanced today, ended up taking an old 998 crank to balance it on.
Went to pick it up and the guy told me he hadn't had to machine it at all because in it's current state it was only 0.7g out of balance! I only had to pay for his time to balance the crank up with putty so the pulley could be balanced.
Couldn't believe it because the welds weren't perfectly neat and had been filed down after.
