| Home > Help Needed / General Tech Chat > Turbocharger condition assesment help required | |||||||
11th May, 2010 at 09:12:51pm
As some of you know, I bought two GT1752 turbos on ebay not so long ago and firstgeneral look over indicated that they were in pretty good condition. Little play in the shaft on both, one better than the other.
11th May, 2010 at 09:22:58pm
i found a load of oil in my IC pipes last night too, well only the one connected the comp housing and a bit of oil sat in the comp housing. Mines a GT20 that was brand spanking new 400 miles tops ago, no massive play or anything int eh shaft either. On 20th Oct, 2015 Tom Fenton said:
11th May, 2010 at 09:36:51pm
most of the cars in work seem to have oil in the intercooler pipes when i take the hoses off, seems to be the norm.
12th May, 2010 at 07:52:47am
Aren't the seals a bit like a piston ring in that thy seal properly when under pressure. So oil will leak through when everything is just sat there.
12th May, 2010 at 08:04:41am
On my mates install the turbo is below the sump (not a mini) and he uses a pump to drain the turbo back to the sump. On the first install when the engine was off oil leaked back through the pump and out through the seals. But when running it was fine.
http://www.twin-turbo.co.uk
12th May, 2010 at 08:07:53am
id hoike em apart colin , i dont have any oil in my pipes ,but the saab breather apparently does put some in , independant of turbo condition .
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
12th May, 2010 at 09:43:56am
id check out the piston clip grooves and the area is seats inside the housing, when i was doing re-conditioning alot had this problem and often found that replacing these solved the problem, as long as the grooze and seats are in good condition anyway.
David. |
12th May, 2010 at 11:25:35am
I am tempted to give the 'newer' turbo a clean up and run that and see how it goes before I pull it apart.
13th May, 2010 at 08:21:45pm
Time to get the DTi out, I managed to find the official SAAB axial play tollerence :) 0.036 - 0.091mm On 26th Oct, 2004 TurboDave16v said:
13th May, 2010 at 09:56:57pm
Also, GT17 actuator factory setting is 0.32bar as it starts to move. On 26th Oct, 2004 TurboDave16v said:
20th May, 2010 at 10:03:14pm
On another note, if you find it difficult to remove the turbine housing from the core, you might find that the housing is infact cracked. Two out of three cracked and the cracked ones were a bit of a bitch to remove. On 26th Oct, 2004 TurboDave16v said:
