Home > Help Needed / General Tech Chat > oil in inlet manifold
rusty
Member #: 8858
Halifax, west yorks
hi,
my turbo mini has been smoking when its ticking over, so i checked the plenum for oil to see if it was the turbo seals, the plenum was bone dry. Just taken the head off as i thought it could be the stem seals, when i took the inlet manifold off there was a small pool of oil in both of inlet bores on the head, is this down to the stem seals or something different?
when i took the seals off they all seemed to be seated correctly and the only real thing that i can see wrong with them is the bottoms of them seemed to be skirted out, im new to jobs like this so a point in the right direction would be great!!!
Kean
Member #: 341
aka T2clubby
South Staffs
yup seals or guides most likely mate. Get the same symptoms on my car.
rusty
Member #: 8858
Halifax, west yorks
thanks for that mate, think ill get the guides changed as well then!
tadge44
Member #: 2500
Buckinghamshire
Steve 1275 experienced a similar problem which turned out to be a valve guide loose in the head.
rusty
Member #: 8858
Halifax, west yorks
Just checked the guides they seem tight in the head but the valves stems have quite a bit of play in the guides.
Got a quote today £40.00 plus vat for new guides and re cut seats. seems quite reasonable to me.
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
That seems like good value alright. some of the lads on here could sort you out.
Where are you based?
snap their hands off *wink* i think its 35 for re-cutting seats at mine
rusty
Member #: 8858
Halifax, west yorks
I took the head in today to w.brown in Halifax, double checked the price because i thought it sounded cheap, definatly £40 plus vat
I pick it back up on tuesday so ill let you know how it looks
