| Home > Wanted > 1293 Engine Block | |||||||
13 Posts Member #: 3865 Member Surrey |
13th May, 2010 at 12:25:11pm
Looking for a 1293 block for my mini project.
Edited by JD88 on 13th May, 2010. |
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
13th May, 2010 at 01:55:36pm
is an MPI block of any use to you mate? I have a 1293 MPI block that's been run up but not driven/run in at all, bored to 1293, fitted with new cam bearings and a centre main strap Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
13th May, 2010 at 04:45:07pm
I'm going down the turbo route using a carb, would that be okay still even if its a mpi block? |
13th May, 2010 at 04:47:25pm
Will you be using a dizzy or mapable ignition? The MPI block doesn't have a dizzy hole. I assume it doesn't have a mechanical fuel pump hole either. And it has a cam sensor hole. I'm sure someone else can point out the rest of the differences On 12th Nov, 2009 Paul S said:
Gary's description is best |
13th May, 2010 at 04:54:12pm
Cheers GaryOS that's great info,
13th May, 2010 at 04:54:43pm
MPI block no goods for you then. If something is worth doing, it's worth doing half of. |
13th May, 2010 at 06:50:24pm
Dizzys are no good either Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
68 Posts Member #: 7711 Advanced Member Beek, The netherlands |
13th May, 2010 at 06:52:51pm
How much will cost thet block prawn?
13th May, 2010 at 07:49:26pm
Well, I was offered £80 for my last MPI block, which was 100% standard.
18th May, 2010 at 07:50:10am
Can now be removed.
Edited by JD88 on 27th May, 2010. |
