Home > Wanted > turbo inlet manifold
strech
Member #: 2214
doncaster south yorkshire
i have a n/a inlet manifold for the hiff44, can i use this or do i need a turbo inlet, if so, does anyone have one ?
*tongue*
Anton
Member #: 764
Staffordshire
I believe you can still your the usual HIF44 inlet, but you may run into clearance problems depending on the manufacturer.
Also the flanges are different thickness to the turbo exhaust manifold, so you may have trouble getting it bolted down tight
As Andy say, but the difference in thickness is considerable (~3mm) - you will need to make up stepped washers or cut some of the thick washers in half and use them as packers.
And that is only if it will fit inbetween the cast exhaust manifold anyway, I "think" the turbo inlet sweeps upwards more sharply to clear it.
