| Home > Help Needed / General Tech Chat > where to buy hex bit? | |||||||
13th May, 2010 at 10:44:13pm
Ive just bought an extended crank damper bolt (the cap head type minispares sell) but I can't find anywhere that sells single hex bits. Im after 1/2" drive 1/2" hex size.
13th May, 2010 at 10:50:58pm
http://www.cromwell.co.uk/KEN5827856K On 20th Oct, 2015 Tom Fenton said:
1050 Posts Member #: 764 Post Whore Staffordshire |
13th May, 2010 at 11:46:19pm
i was a pikey and have always used a the metric equiv |
14th May, 2010 at 07:42:37am
Halfords sell individual bits Fastest 998 mini in the world? 13.05 1/4 mile 106mph
14th May, 2010 at 08:25:14am
Hex bolt for the crank damper? What a terrible idea bearing in mind how tight you have to do it! Sounds a recipe for rounding off! On 5th Sep, 2011 Vegard said:
14th May, 2010 at 08:36:02am
On 14th May, 2010 Scruffy said:
Hex bolt for the crank damper? What a terrible idea bearing in mind how tight you have to do it! Sounds a recipe for rounding off! Well it has been sold and used for quite a lot of engines for 10 years at least, and I have never heard about any other problems other than it being a bit too long for some cranks, so I do not think that is a problem if you have the correct tools |
![]() 159 Posts Member #: 1997 Advanced Member Lichfield |
14th May, 2010 at 09:55:42am
On 14th May, 2010 wil_h said:
Halfords sell individual bits not 13mm or half inch allen bits though - ive looked cos i have the same crank bolt |
14th May, 2010 at 10:10:35am
What's the compelling reason for 1/2" drive?
14th May, 2010 at 10:14:29am
Halfords only go up to 10mm Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 168 Posts Member #: 1772 Advanced Member Leicestersheershire |
14th May, 2010 at 10:54:28am
Fleabay?
Tim Rowe
14th May, 2010 at 11:48:05am
I ended up making one from a 1/2" allen key cut down welded to an old 1/2" drive 13mm socket.
14th May, 2010 at 01:35:38pm
On 14th May, 2010 apbellamy said:
What's the compelling reason for 1/2" drive? probably because most big torque wrenches are 1/2" drive and you need to use a big torque wrench on that bolt |
14th May, 2010 at 01:37:53pm
1/2" to 3/8" drive converter? If something is worth doing, it's worth doing half of. |
14th May, 2010 at 02:28:45pm
Ive just bought that set on ebay for £8. I tried using an 5/16 bolt with a spacer and nut welded to it in a desperation but it just twisted under the torque. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
14th May, 2010 at 02:50:51pm
You sound like my kind of engineer, Tom.
14th May, 2010 at 03:40:02pm
I hate not being able to finish a job and having to wait a few days for things to come, it is amazing what you can come up with given a bit of ingenuity.
14th May, 2010 at 04:03:19pm
If I had a 1/2" allen key I would of done the same. I hate not being able to finish a job, it'll be mid week now before any progress. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
14th May, 2010 at 04:22:29pm
Mad idea I know, but why not go to a shop? I know it's a bit old fashioned, but it might just work On 11th Feb, 2015 robert said:
14th May, 2010 at 04:55:32pm
Good idea in principle, but you try and find somewhere with one on the shelf!
14th May, 2010 at 05:47:36pm
^^^^exactly, with it being imperial it makes it even harder to get hold of. We have some good tool shops around here and none of them stock anything above 10mm! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
14th May, 2010 at 06:29:32pm
On 14th May, 2010 Tom Fenton said:
Good idea in principle, but you try and find somewhere with one on the shelf! I needed a 3/16" hex bit for the DON, tried everywhere I could think of in Sheffield and Rotherham, no joy. Had to order one. There's a really good tool shop at Attercliffe near the railway lines. Had loads of this type of thing in, but I wasn't looking specifically at them.... On 11th Feb, 2015 robert said:
14th May, 2010 at 06:42:59pm
I ended up making one from a 1/2" allen key cut down welded to an old 1/2" drive 13mm socket. That is what I did for the 17mm hex on the driveshaft doing the cv gaiter on the Passat last week after buying the special tool that tom recommended for the clips. Turned out the bloke was only 12 miles away! On 5th Sep, 2011 Vegard said:
