Home > Help Needed / General Tech Chat > servo nut in the top of the inlet manifold?????????
MiniVanMan
Member #: 5262
Yeovil, Somerset
Does anyone know where to get the nut (i think its meant to be a banjo bolt) that goes in the top of the inlet manifold for the brake servo take-off pipe??????.............................
its the hole right in the middle of the inlet manifold on the top
CHEERS GUYS
You need a 5/8 UNF Banjo bolt. Try your local hydraulic specialist.
MiniVanMan
Member #: 5262
Yeovil, Somerset
AWESOME STUFF!!! cheers il get down there asap...
THANKS *happy*
I'm 99% sure it's the same as the banjo bolt for the oil filter.
jamz
Member #: 2292
Tool
Herne Bay, kent
i need a bung i can dill to put a vacuum take off here
cant beat a good blowout.
Get a 5/8 UNF bolt and drill/tap for a 1/8 BSP thread
t3gav
Member #: 229
Gavin@minispares.com
kent
Yes it's the same as the block bolt http://minispares.com/Product.aspx?ty=pb&pid=33787&title= if you get stuck. (2 in stock at our north branch)
gavin out of curiosity, which one for the spi block, im certain mine doesnt fit
cheers
It's 11/16 UNF for the SPi block Brett
http://minispares.com/Product.aspx?ty=pb&pid=34398&title=
cheers andy, interestingly, more oil = more bhp on that link, how many you think 10? *happy*
15 if you use red oil
lol
it's an interesting point, and could have some truth to it,
imagine you are running 50 psi on the gauge (which is fed from the oil gallery after the filter) if the banjo bolt arrangement drops 5 psi then you are having to make an extra 5 psi at the relief valve, so the oil pump is consuming more power.
as a for instance my oil pressure is about 45-50 psi until the oil warms up a bit, then it goes up to 55-60 psi
On 17th May, 2010 mini13 said:
lol
hmmmm my oil pressure is 40-45 then when it warms up 0-10 lmao *happy*i see what you mean though the pump doesnt have to work as hard to pump it through a larger pipe
MiniVanMan
Member #: 5262
Yeovil, Somerset
yeah it is the same as the oil filter pipe so i just hacked up my spare pipe.. Im running a cooler so i already had the nut on the shelf CHEERS GUYS :)
