| Home > General Chat > Project Lathe | |||||||
14th May, 2010 at 07:24:21pm
I know a few of you are interested in this so here is its own topic.
14th May, 2010 at 07:27:36pm
As with most industrial stuff, it had a 3 phase motor.
14th May, 2010 at 07:31:58pm
result, tom , well done . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
14th May, 2010 at 07:33:04pm
Perserverance paid off there!
14th May, 2010 at 07:42:32pm
top stuff tom.............. your so tight though.....LOL .....
14th May, 2010 at 07:47:08pm
Tidy lathe. I'm hopefully picking my colchester up next wekend. |
14th May, 2010 at 07:55:20pm
Well that looks a tidy piece of kit.
![]() 116 Posts Member #: 4273 Advanced Member stoke on trent |
14th May, 2010 at 08:07:21pm
looks ace mate well done can you find any more knocking round :) |
14th May, 2010 at 08:17:26pm
excellent Yes i moved to the darkside |
14th May, 2010 at 08:21:54pm
On 14th May, 2010 Tom Fenton said:
As with most industrial stuff, it had a 3 phase motor. After weighing up the options I decided a single phase motor was the easiest and cheapest solution. Here it is mounted on some adaptor brackets, as it is slightly physically smaller than the old motor. ![]() Tom, have you got a link to the site you got that "single" phase motor from ??? If it's what I think it is, it might be reversible (as you questioned in your previous thread). Schrödinger's cat - so which one am I ??? |
14th May, 2010 at 08:41:53pm
Hi Rod, it was an ebay special!
Edited by Tom Fenton on 14th May, 2010.
14th May, 2010 at 08:46:24pm
14th May, 2010 at 08:48:25pm
Indeed, the slant bed although unusual is pretty smart thinking really.
14th May, 2010 at 08:51:56pm
Hi Rod, it was an ebay special! However, the wiring instructions do show it to be reversible depending on which way you wire it up, and move a couple of links. That's what I thought from the photo, 6 terminals (although two are slightly out of view) which means it is a dual 3 phase / single phase (with the capacitors) so could be switched for both directions in either 3 phase or single phase configuration. I've seen a couple of these recently, a neat idea so leaves options open for the future, even if you don't need it now. Schrödinger's cat - so which one am I ??? |
14th May, 2010 at 08:56:01pm
It does indeed have 6 terminals like a 3-ph motor.
15th May, 2010 at 12:03:57am
ill give you £50 for it |
15th May, 2010 at 10:40:21am
bargain, what size motor did you go for?
15th May, 2010 at 02:18:18pm
2HP, the same as the old one was.
16th May, 2010 at 08:59:49am
It will come in useful tom, although you'll find yourself wanting a milling machine next no doubt as i do!
17th May, 2010 at 06:42:41pm
Well a small update here.
17th May, 2010 at 06:50:10pm
17th May, 2010 at 06:52:43pm
The first job is to hopefully make an adaptor to mate a small single phase motor I've acquired to the old suds pump which currently has a 3-ph motor attached!
