Home > For Sale > Lots of bits!
Owen
Member #: 6496
Somerset
Righto chaps, having a bit of a clearout!
Metro rad with fan (both outlets on same side) £30 posted
Tacky push button start panel and cable £20 posted
Rev counter (auto garage i think) with shift light £35 posted
Air/fuel ratio gauge £15 posted
Boost gauge £20 posted
Dynamx water temp gauge, BNIB £25 posted
Mini heater box £40 posted
Mk 4 clusters with clear lenses £35 posted
Adjustable rear camber brackets £30 posted
Solid front subframe mount kit (incl teardrops) £25 posted
Rear subframe, needs patch, collection only £20
Standard brake master cylinder £30 posted
Brake limiter valve £30 posted
Clutch master cylinder £30 posted
Adjustable tie rods, bottom arms incl poly bushes £60 posted
I also have the following
Maniflow 1 3/4" link pipe brand new £25 posted
Steering column with stalks and wheel £35 posted
Almost new steering rack £40 posted
Front and rear hi-lo's with very good donuts £65 posted
Sealed beam headlights with bowls £15 posted
Basically I bought a mini, but it wasn't all it was cracked up to be so if you need any little bits give me a shout and i'll see if i've got them!
Owen.
On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair
Sam
Member #: 1686
Oxford
Wanna do a deal on the
and
Thanks
Sam
OMG Robert that's a big one
Owen
Member #: 6496
Somerset
Sam, YHPM
coleman262
Member #: 8904
Bexhill, South East
are the collumn stalks from a mk3?
Owen
Member #: 6496
Somerset
They are twin stalks. I.e. indicators etc one side, wipers the other. :)
pickmeup
Member #: 1200
alright owen, you still got that 998 for me? will pop down and see you sometime soon for a catch up.
eaton_mini
Member #: 1649
West Sussex - dreaming of forced induction!
can you pm me some pics and dimensions of metro rad please.
