| Home > Help Needed / General Tech Chat > Drop Gears or Box Gears.. S/C | |||||||
![]() 334 Posts Member #: 7169 Gobshite that posts wank videos. Somerset, UK |
16th May, 2010 at 10:01:52pm
This may seam like a stupid question to some but, where should the money be spent first when it comes to S/C gears,
Gaball said:
Motorsport Engineering Student Project Car 1293 Turbo Mini (on a student budget) On 7th Oct, 2010 apbellamy said:
Carbon but plug? |
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
17th May, 2010 at 12:40:40am
if your helical box is in good order theres no reason you couldnt run it with just sc drops for now... im running sc drops and a helical box. :) On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
![]() 141 Posts Member #: 7891 Advanced Member Annapolis, MD USA |
17th May, 2010 at 03:23:10am
Well....I'm not even turbo yet....I did a 1380 build with a stock a+ box/gears with cross pin diff & straight drops....found the next weak link....this was after 100 miles and I wasn't even ripping on it.... Eric
17th May, 2010 at 07:27:48am
im running 188 bhp on stock helical drops , broke the helical box at 150 bhp . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th May, 2010 at 05:37:06pm
:( im going to run mine at approx 140 for now, see how long my helical box lasts then. :S its in good condition and is having an some sort of uprated layshaft to test it. not sure exactly on the details but ill ask about it next time i pop in. :) Edited by Rick.SPI on 17th May, 2010. On 17th Feb, 2011 apbellamy said:
19th May, 2010 at 09:56:02pm
yep prime example to much torque will shred the input gear just like that if there is to much traction always looking for them bigger bunches of bannanas |
19th May, 2010 at 10:48:25pm
Hogster, check this thread:
Gary's description is best |
20th May, 2010 at 04:35:16pm
i remember benross saying in another thread the drop gears loudness depends on what set you get, theres one thats fairly quite from all accounts :/
Carbon but plug? |
21st May, 2010 at 03:21:51am
Drops are good, but as I have proven....you still need some good gears in the box....also, what diff are you running? Another weak point to consider with lots of power. Eric
Guess she's makin' some torque...
