| Home > General Chat > OT - Spraying Base Coat | |||||||
458 Posts Member #: 1840 Senior Member Kings Lynn, Norfolk |
18th May, 2010 at 12:24:17am
I'm a bit embarrased asking this due to being a machine painter by trade, but i dont ever use base and clear at work.
18th May, 2010 at 06:22:44am
You want 2 bar pressure, make sure the air hole in the pot isnt blocked, have you thinned the base? or is it pre - thinned? Metallic or straight colour?
Edited by paul wiginton on 18th May, 2010. I seriously doubt it! |
18th May, 2010 at 07:23:31pm
Ok will revert back down to a lower pressure, air hole wasn't blocked as it was a brand new gun used for the first time.
18th May, 2010 at 09:25:05pm
1:1 with thinners is about right, hardener is NOT used in base coat, metallic does come out blotchy - its the technique that makes it even which is hard to explain. Hold the gun about 12-14" from the surface to be painted and use even strokes flicking the wrist away from the panel at each end. You need to build up layers, usually 3 normal coats then a 'drop coat' where you hold the gun about 24" from the surface and dust the paint on, this allows the metallic particles lay in the same direction which stops it looking blotchy or streaky.
180 Posts Member #: 373 Advanced Member Leeds |
18th May, 2010 at 11:00:40pm
i'm assuming this is celly paint then? Ive never sprayed celly but done loads of 2k where the base coat is 2:1 with hardener.
"I'll get there in the end" |
18th May, 2010 at 11:37:38pm
Some solvent base is 2:1 and others 1:1, depends on brand.
19th May, 2010 at 12:34:48am
Have given the base another good 3 coats tonight, the drop coat method seems to have helped, not heard of that before.
19th May, 2010 at 07:58:28am
On 18th May, 2010 cossierick said:
Some solvent base is 2:1 and others 1:1, depends on brand. all paint and thinner NO hardner. Laquer usually 2:1 or 3:1 10% thinner celly is usually how ever much thinner you fancy, very old school before my time. Basicly as wiggy says. rick yeah, yeah, what do you know rick
I have only used MIPA 2k paint and that is 2:1 with hardener or at least that is what it says ont tin
Paul "I'll get there in the end" |
21st May, 2010 at 08:53:14am
What paul ha advised is bang on the only modification I would make is to turn the paint down a little.
Own the day
