| Home > Help Needed / General Tech Chat > Piston failure | ||||||
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
29th Jan, 2005 at 09:11:49pm
I had a piston fail today it has broken the top two rings and the ring lands only 1800 miles since a rebore. |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
29th Jan, 2005 at 09:15:17pm
who knows!!
29th Jan, 2005 at 09:23:55pm
Thats what I thought about boost,I am not fussy about blaming anyone just dont want the same to happen again. Edited by AllanMcD on 29th Jan, 2005. |
29th Jan, 2005 at 11:03:00pm
which +040 piston?
29th Jan, 2005 at 11:10:13pm
Yes they are mega pistons. |
29th Jan, 2005 at 11:13:47pm
Allan you running an intercooler ?? because it sounds like a classic case of detonation to me...
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
30th Jan, 2005 at 06:18:39am
No intercooler but there isn't any sighns of detination on the crown of the pistons.
30th Jan, 2005 at 04:05:24pm
Detonation kills pistons easily. First the top ring gets tight in the groove, then the hammering is concentrated to the ring land and voila. Old powermax pistons were famous for looking great but came out in pieces, usually the ringland was loose between the rings. |
30th Jan, 2005 at 10:36:09pm
Sounds like Det to me too...
AlexF |
30th Jan, 2005 at 10:46:16pm
I didnt know that.
Edited by AllanMcD on 30th Jan, 2005. |
30th Jan, 2005 at 11:22:22pm
what boost, ign advance and fueling where u running?
AlexF |
31st Jan, 2005 at 08:15:26am
9 psi
Edited by AllanMcD on 31st Jan, 2005. |
1st Feb, 2005 at 08:48:57pm
Got a new piston today also new valve guides the inlet valves were all wet with oil I thought I had turbo problems before so I got a good used turbo which I put new seals and bearings in just to be sure it was ok, but it still smoked at tickover.
2nd Feb, 2005 at 08:54:59am
You need to get it setup...
AlexF |
