Home > Help Needed / General Tech Chat > Oil drain and MPI block
Right looking to my new build, i have a nice MPi block here what options do i have for turbo oil drainage?
any ideas?
Edited by wolfie on 18th May, 2010.
5 port push rod? cam sensor hole?
16v twin cam? drill a hole into the tappet chest *wink*
5 port push rod
Thinking about it, the cam sensor hole is perhaps a little higher than the old fuel pump hole *oh well*. I see no harm drilling a hole in the skirt of the block.
as mentioned there is the cam sensor hole,
or if your not using the speedo it can go in the speedo take off,
I have seen breathers put through the block next to the cam sensor too,
other than that the next easiest would be to tap a hole in the gearbox.
Arnoud
Member #: 1085
Netherlands
just curious: where do you plan to get oil supply to the turbo from? I'm thinking of building an MPI-block based turbo engine but this appears to be a problem?
1963 Cooper
1975 Pick Up
Same place as the oil feed is taken from on the A+ block
I'm using an MPi block for my build. Carl is tapping the hole to something suitable so I can bung it up. Nothing stopping you threading some tube and putting it in there.
1/2" NPT hole now in the back of the block for mine. LOL, thats just another 1 out of 2 holes extra to what seems like another thousand holes I have drilled in this block already.
