Home > General Chat > wellseal on head gasket
Watched the car is reborn tonight where there rebuilding an E Type
When they refitted the Jag het they used a coated gasket like the bk450 and used wellseal on both sides
Anyone seen that practice before?
tadge44
Member #: 2500
Buckinghamshire
Cant do any harm IMO.
I always use a slather of grease each side, to help the gasket settle.
Wellseal can be a sod to get off afterwards tho,
evolotion
Member #: 83
Glasgow, Scotland
i wouldnt, i have used wellseal when experimenting with shims on my engine, and it does work, but a gasket should only mate to clean flat surfaces imho :)
Denis O'Brien.
I do it dry.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
On 19th May, 2010 mini13 said:
I do it dry.
Duuurty!
On 30th Apr, 2010 Rod S said:
Gary's description is best
I do it dry.
Duuurty!
Straight up no butter!
IMO coated gaskets (like the BK450) should only ever go on clean dry surfaces.
Otherwise, how is the coating supposed to work ???
I clean both surfaces with acetone (cellulose thinners) to make sure they are dry and grease-free before installing that type of gasket.
I do it dry.
Me Too
