Home > General Chat > More holes
What are the pros & cons with holes in the cover i have been thinking why lads do it
you might drop a 10mm spanner in there and never notice.....
Twat
It looks blingin innit
pinkyandnobrain
Member #: 2588
Pretoria South Africa
I think the main reasons are to aid cooling of the clutch and there is also a slight weight saving.
And as they as every little bit helps
"Try to take over the world!"
PaulH
Member #: 2340
Dublin Ireland
Careful tho If you do a lot of wet weather driving like retro rally or the likes water can get splashed in and cause clutch slip have had that happen :(
On 17th Feb, 2009 Rob H said:
I saw pictures of a wok rescently with holes in the top third and counter sunk holes on the inside of the rest of it.
t@z
Member #: 452
Chester, UK
pros - can see your clutch if enough holes
cons - looks like cheese
apbellamy, i think paul w's is like that i have a pic somewhere here.....*runs off to find it*
tada this what you mean?
Edited by t@z on 19th May, 2010.
www.twitter.com/lilpinkiy
Fook!
That's the one, obviously I don't plan to plagerise that at all...
Looks good and very light, but i got bored drilling 5 holes in my subframe so id never get to that extent.
t@z
Member #: 452
Chester, UK
i'm not even gonna post a pic of mine against that as i just attacked mine with a hole maker and looks like cheese lol
much lighter though *happy*
I'm not going to that extent as it's a road car, but I will be using that style of modification.
if you have enough holes you can see whats broken lol
t@z
Member #: 452
Chester, UK
i might put this on my car
yes as has been said meant to add cooling, the cons are dropping nuts and bolts down them if to big, AND if you have an oil pipe over that side of the engine blow off, your clutch get covered! far from ideal!
On 19th May, 2010 Miniwilliams said:
the cons are dropping nuts down them !
Edited by Joe C on 19th May, 2010.
Si P
Member #: 912
North Yorkshire
They look to be about the right size to me. some people go OTT with 20mm plus.
As said before heat is the main reason. I also hack off the starter KNOB. It gets in the way. Only if your running a small light weight starter mind you.
Si
I drilled mine partially to save weight but mainly to aid cooling as it does get fooking hot!
I made oles cos I kood
On 19th May, 2010 t@z said:
pure dedication that is *wink*
nope pure dedication is on the other side where the gasket face has had the same treatment!
