Home > General Chat > Oil leaking dye
munnracing
Member #: 5193
Dunstable
Hello,
I seem to recall a thread probably about a month or 2 ago about someone having some dye to put in the oil in the engine to find an oil leak, i know you have to use a uv light to find the leak but i cant find anywhere in the uk that has the stuff in stock nor can i find the thread on here.
Does anyone have any ideas?
Cheers Josh
Isnt black oil good enough for you josh lol
http://www.carairconditioningsupplies.com/caraircon/home.php
The glasses are well worth the extra! Trust Me!
munnracing
Member #: 5193
Dunstable
Its on a car at work ive been trying to find the oil leak for weeks now and cant find it you leave it for a day or so and oil just appears but you cant see the trace and its doing my nut in
evolotion
Member #: 83
Glasgow, Scotland
Heavily degrease with brake cleaner, then spray everywhere with leak seaking spray(basically aerosol talcom powder)
what engine is it? Mibby someone can give you a pointer?!
Denis O'Brien.
munnracing
Member #: 5193
Dunstable
a c20let with a t28 turbo in a vx220 ive had the gearbox in and out of the car 5-6 times and its getting a bit tedious now as it drips from the where the gearbox meets the engine rite at the bottom well thats where the oil drips onto the floor from ive replaced 4-5 crankshaft end oil seals had the turbo off and the inlet off looking for this leak and still have yet to find the leak at first i thought it was to much pressure build up in the crank casing but we have run a couple of tests and all seem to be fine.
Thus the reason looking for some oil tracing dye or the likes.
Gearbox input shaft oil seal ???
Or is it definately engine oil rather than gearbox lube.
munnracing
Member #: 5193
Dunstable
it is definately engine oil rather than gearbox lube as ive left the gearbox off of it overnight and the oil appears
evolotion
Member #: 83
Glasgow, Scotland
corner of the head gasket? dizzy drive hole? sump gasket? .. just stick a tampon under it and forget about it lol
Denis O'Brien.
If there is so much that it leaves a pool of oil, there is no way it isnt leaving a trace of where it has come from
madcatminis
Member #: 5327
Dudley, West mids
C20xe's are notorious for leaking oil from the rubber cam cover gasket. The C20let is basically the same engine so I'd inspect that matey. *happy*
Carl
Member #: 95
liverpool-on-sea
have you checked the surface where the rear main seal sits for damage (i.e scredriver gouge marks)where its been removed previously.
have you checked theres not a deep groove worn in the crank by a old seal?
i would take gearbox off put on ramp degrease it and then get some leak seek (as evo suggested) and give it all a good dusting, it will show up
munnracing
Member #: 5193
Dunstable
During the many times ive had it in and out ive looked for damage in the rear main seal area no marks their were a few tiny ones but i got a bit of emery paper and got rid of them with little to no effort, we havent got the proper tool to put the seal in but using the glossy part of the magazine and a flat bit of metal makes them slip in all be it a bit hard but the end result would be exactly the same using the correct tool.
The gearbox is off at the moment ive made a engine mount so i can run the engine in the car with the gearbox off to try and find the leak one thing im definately going to do is do as evo suggested and get some of the spray powder first if not then ill have to get the dye
Ill take some pictures of the part where its leaking when im at work tomorrow
Cheers for everyones comments
Josh
munnracing
Member #: 5193
Dunstable
it is wierd in the way that the oil appears but when trying to trace it, it is very difficult i will try and take a picture when im at work tomorrow to show everyone what i mean
munnracing
Member #: 5193
Dunstable
ive checked the head gasket and ive replaced both sump gaskets and the probelm is still occuring i wish i could just stick a tampon under it but i dont think its very practical in the long run lol
evolotion
Member #: 83
Glasgow, Scotland
could be a casting flaw/crack seen it a few times on engines pulled out of written off cars as donors *wink*
Denis O'Brien.
