Home > Help Needed / General Tech Chat > What changes are necessary to ditch ECU
Aussie_Dan
Member #: 461
Queensland Australia
Can some one direct me as to what mods are necessary when removing the ECU. Also what is the difference between an A+ dizzy and a turbo dizzy.
Dangerous
Member #: 417
The activater for ecu use is only rated at 3psi,uprate this or fit bleed valve and gauge.
dizzy---advance curves way differant
Basically, leave the ECU on the shelf of the workshop.
Wire up the ign as you would normally (give it a 12v ign live) and that's your lot. (the ECU had NOTHING at all to do with the ign system, all it did was limit the peak torque by contolling boost)
The pipe that went to the ECU block off.
Now It'll run all day long at 3/4psi. To get more boost, fit a bleedvalve - look in the 'how to' section for details on this.
Edited by turbodave16v on 29th Jan, 2005.
