Home > Help Needed / General Tech Chat > Recommended Cam shafts.
cordantium
Member #: 31
62horses at the wheels and counting
Can any1 recomend a good cam shatf to use in a turbo engine.
Ideally I would like the boost to kick in at lower revs/reduce lag.
Thought and comments please.
TA muchly
Keith
I have used the Phase 2 and can recommend it. It's certainly street drivable, with no lumpy idle etc
As for reducing lag, well it does seem to pull the bottom end up slightly when off boost, and pulls well throughout the rev range. Certainly a good cam for a fast road motor.
The normally aspirated MG cam, the Kent 266 and Swiftune SW5 may be worth a look at ? though i've not tried these myself ?
Jimster uses the Phase 3.
Phil. *smiley*
