Home > Help Needed / General Tech Chat > New Starter Needed
Flo
Member #: 6322
Bawdeswell, Norfolk
Hi all
What would guys suggest would be the best starter for my Marcos. Running an 8v Twink, approx 10.5 compression, and a pre-verto clutch/flywheel setup?
Thanks
Matthew
Nick
Member #: 154
Midlands
an inertia one, assuming you have the std ring gear on the flywheel?
Flo
Member #: 6322
Bawdeswell, Norfolk
Hmm. Now I feel a little stupid... The flywheel was supplied by SC. Looking at it, how would I tell the difference?
Count the number of teeth on the ring gear.
107 for inertia starter and 129 for pre-engaged.
Obviously usually the 107 is on a pre-verto assembly and the 129 on a verto but the specialists often put the 129 on a pre-verto flywheel to allow use of the later starter motor. (mine is setup like that).
Edited by Rod S on 22nd May, 2010.
Flo
Member #: 6322
Bawdeswell, Norfolk
Then in that case, a Pre-Engaged Starter will be needed... Whats best?
On 22nd May, 2010 Flo said:
... Whats best?
Can't really comment specifically for a Marcos but if you are looking at standard items the Mini version and Metro version are subtely different - the solenoid is dead front on the more common Metro version but moved upwards and inwards on the Mini version (as the Mini required more front clearance).
Flo
Member #: 6322
Bawdeswell, Norfolk
I have loads of space infront of the engine, but obviously I need to clear the throttles. Just wondered if the uprated ones are worth the difference, or if they are needed for the higher compression rate?
Ben H
Member #: 184
Melton Mowbray, Pie Country
If you want the best then get a proper modern starter. Something like this:
http://www.ccw-tools.com/product.asp?P_ID=12775&af=1792
I am not suggesting to buy it from there it is just the first place I found one.
http://www.twin-turbo.co.uk
I bought mine from Moss when they had a VAT free day, and its pretty much identical to the one linked to above.
The pre engaged starter should be more than enough though. I only bought the high torque one to save a little more space at the front, but given the choice again, i would buy another.
Edited by Sprocket on 22nd May, 2010.
