Home > Technical Chat > Plenums and ram pipes
After reading though a few threads ie Joes 7 port and Rods 5 port i noticed that the ram pipes protrude into the plenum significently
Whats the theory behind this as i would have thought that this would not be ideal airflow or is it better to dirupt airflow in the plenum?
or is the heat getting to me
mine are like that as it was easier to do it that way,
there are some good pic's of flush stuff here, as you'd expect they are flush...
http://www.rossmachineracing.com/20vVWintake.html
Ben H
Member #: 184
Melton Mowbray, Pie Country
Putting a proper stub stack type inlet has the same benefits in a plenum as it does in an air filer. Although having squared off edges like the two shown will not be as good as a stub stack or ram pipe design.
http://www.twin-turbo.co.uk
I use these bellmouths, basically because the yelow bible suggests that it is one of the best shapes.
They stick into the plenum by about 30mm.
Coupled with a long runner, I seem to be getting good torque from low down on the 998T.
where are they from Paul?
I machined them up from solid.
I recently made these for the 1293T:
A bit more here:
Missed alot of your thread Paul bloody clever stuff!
Thanks.
I'm not sure why I put the bellmouths towards the middle of the plenum. the triple injector manifold is Version 15 of my designs. Version 2 had the bellmouths in the same place.
I must have read it somewhere, but can't remember where. I probably plaguerised TDs design :)
I used them on mine as I read that the bell mouth design helps to keep air speed up as it changes direction. Sharp edges cause masive losses in air velocity.
My machinist made an error interpreting my drawings, so I ended up with a comprimise to recover from said mistake, but, there is a 6mm radius leading to a bell mouth almost the full length, so it at least has to be better than just a straight 38mm opening :)
Edited by Sprocket on 24th May, 2010.
TurboHarry
Member #: 115
Austria, near Vienna
http://www.minifreunde.at/harry/links/inletsystem.htm
Harry
Bimmer Twinky headed and turboed A-Series:
http://www.minifreunde.at/harry/projects.htm
I didn't spot this when it was first posted....
The main reason I did mine the way you show in the first photo is that I'm copying (as far as possible) the Cossie design for all my injection system and they stick into the plenum/airbox.
However, the Cossie ones are much more rounded bell mouths than the ones I machined up, but mine is only a trial so far.
Also, it is a common modification on the Cossie to fit a spacer plate between the two halves of the plenum/airbox which would make the (four) inlets less intrusive in the box. It's not clear if this works because of changing the airflow into the trumpets or because of the increased size of the plenum.
I personally tend to think that once the plenum is under pressure (ie, boost) the exact shape becomes less relevant.
Having said that, I have built in a splitter plate (which you don't see in the photo) to ensure equal distrubition to the two runners......
jbelanger
Member #: 831
Montreal, Canada
I would think that fluid dynamics would still apply no matter what the pressure is. Of course, the optimum shape and size might be affected but the principle should still be valid.
And even under boost, optimizing flow will be beneficial since you will achieve the same air mass flow with less boost.
Jean
http://www.jbperf.com/
Yes, the rules still apply - my simplistic point is that on a normally aspirated engine the pressure difference (which drives the air mass flow) would be very low at that position and can't be increased, so optimizing the flow regime is very important.
Once you have forced induction you can compensate for poor flow just by increasing the pressure difference. I agree optimizing the flow path has to be beneficial as less boost will be needed to achieve the same mass flow but there are a lot worse restrictions in my nightmare of plumbing.
A good example of poor design in my case - and probably most standard factory items - is to look inside the intercooler header. Pretty much the same principle as the plenum, a large box feeding smaller tubes. The tubes are rectangular and pressed through the endplate leaving a small upstand and it is all sharp square corners.....
But back on the original point, like Paul, I too think I have read somewhere about having them protruding into the middle of the plenum but this can surely only give an advantage if they are fully radiused all the way around to the back (as Paul's first photo) which I did not attempt to do.
Final point, by having them protrude in, the runner length becomes longer for the same physical size of plenum and longer runners are supposed to improve torque.
Interesting Robert,
Do you know if that is measured or computer modelled ???
And under steady state (flow bench) or real individual pulses ???
At least the ram pipes / stubs, whatever you want to call them, protrude a fair way into the plenum....
Well, this is the current state of the Miglia Turbo inlet:
As soon as I had tacked on the end plate, I realised that I need to change the design and move the TB plate further back with a taper from the plate to the plenum body. Never mind.
What volume are you using inside there Paul ???
I've worked on 1.3 - 1.6 times the engine capacity which I've read on here and other sites is the optimum for forced induction but it is giving me lots of problems fitting it all physically in.
Yours looks smaller overall (although obviously a photo can be very deceptive).
On 29th May, 2010 Rod S said:
Interesting Robert,
no , im sorry rod , no more info on that ,, i found it interesting that the pressure gets gradually less in the inlets as you go from small end to large .
It's around 1850cc for the cylinder (10cm dia by 23.5cm long), so it should be around the correct volume. By the time I add the taper it will be near the 1.6 times engine capacity.
The 998T is running something similar, but a bit shorter, so it is also running at around the 1.6. Although that has much longer runners, overall it gives a very torquey feel and revs well.
On 29th May, 2010 robert said:
.... i found it interesting that the pressure gets gradually less in the inlets as you go from small end to large .
Me too, as if the taper was too great and putting excess pressure in the small end.
Also noteable, the first two (from inlet end) get the lowest pressure at their first edge, almost as if the shape of the trumpet at 90degree to the mass flow is acting classic Bernouili (ie, pressure drop over an effective aerofoil section).
That's why it would be interesting to know if it is simulated or real.
That's good, it looks less in the photo.
Mine is virtually 1.6 (on a 1360) but a struggle to fit despite my using a rectangular section which should be more space effecient.
Well, actually it won't be 1.6 anymore as I've just hacked a bit out of the bottom to try and run the compressor outlet pipe "through" it......
Next one will be a lot higher up and further back but shortened to clear the clutch master cylinder.
I guess that it is a constant flow simulation in CFD.
Any fluid in motion has a finite energy, either velocity or pressure or a combination of the two. If you speed it up, the presure will drop, converting pressure to velocity energy. If you slow it back down again, the pressure will return. That's why the pressure is higher at the trumpet furthest from the inlet.
It looks very fancy, but I have a distinct impression that they are not seeing a true picture, as the inlet velocity looks higher than the port velocity, whereas in reality the peaks would be much higher in the ports.
Edited by Paul S on 29th May, 2010.
id imagine its off a simulation program i have a copy of rod .,its used by a lot of design houses , , it looks the same as that output .its usually very close to real world ,as long as the input data is accurate .
but in this case i think its a bit of a simplification ,its not including the back pulses from the seperate cylinders intereacting with each others flow , i think they are assuming the area precludes velocity pulse effect to a degree .
im tending more towards the toyota type of plenum nowadays ,especially if running propane in the inlet , as i have been doing on my latest engine .
Well it looks like Version 12 of Ansys CFX does transient simulations. I'm sure than when I looked at V9 it did not.
That means that you can put in time based boundary conditions rather than fixed flow or pressures.
I wonder if you could use it to identify the pressure pulses by including the whole inlet tract? I doubt that it will allow you to add a pressure pulse boundary condition in addition to a flow pulse. Maybe.
I'm tempted to try this on my manifold, just to identify if I actually do need to modify it. After all, this is similar to what I do for a living, so should not be too difficult.
