Up for sale as im having a clearout of duplicate tools etc.
90Amp dual mig, currently setup for gas (takes 5min to switch to gasless), the lowest power setting was ideal for a mini shell.
Pickup from Durham area north east only due to weight. about 18 month old as new, new torch head, half a reel of 0.6gas wire, brand new 0.9 gasless reel. plenty or tips for both sizes. Always kept under the stairs in the house (to avoid mig wire rusting) much to wifes annoyance.
Comes with Disposable bottle style reg (i used argon/co2)
May be used with gas as a conventional MIG welder or without gas using flux-cored wire.
90amp maximum weld current, 40amp at 60% duty cycle.
Ideal for outside use since there is less chance of blowing away the shrouding effect of the gas.
This Clarke MIG90EN mig welding machine features:
90 amp, 40% duty cycle, 230 volt supply.
0.6/0.9mm wire, 4 power settings.
3-4mm maximum weld metal thickness.
£80 due to niceness! (and there twice that new), PM if interested
