Home > Show Us Yours! > New engine build
On 24th Aug, 2010 dan_up said:
! love seeing 7 and 8 inch jobbies!
er... did you see those at the public toilet too?*surprised*
Edited by robert on 24th Aug, 2010.
I used these fittings on my home made rail:
http://www.speedflowshop.co.uk/-06jic-male...3-06-1206-p.asp
The plan is to seal them with an 'O' ring.
As long as the bore in the rail is not too big for the 1/2" thread then that would be fine.
dan_up
Member #: 1835
Thame, oxfordshire
oooh you swine robert! lol.
On 23rd Aug, 2010 Nic said:
Turbophil had a butt plug made that seemed to be suitable. He may have finished with it now and have it kicking around spare
Phil its from a place called ross machine, its cheaper from there ebay shop than online store
Thanks Neil, on American ebay I presume ?
looking good wolfie ............... £7 for 17 inches was a good deal i think........ yes it was ...lol
not much progress, started taking out the machining marks from the bellmouths and i ended up them polished
drawing done and angle worked out for injector plugs, terry should be drilling this week anso plate made for the throttle body, fingers crossed that this should all be glued together end of next week
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Beautiful !
"Try to take over the world!"
Machining of plenum is 90% finished, still slow progress but progress non the less.
Nice!
Dont let some monkey who's never tigged before weld yours together like I did PMSL
That's a bit sexual
pinkyandnobrain
Member #: 2588
BUGGER ! Now I need new pants and a new keyboard !
Looks stunning mate.
the injectors are at a nice angle btw,
how are you going to seal the plenum to the head? gaskets or maggard seals?
Very nice that neil, as joe says lets hope the welder can weld.lol
Rick
joe, as i am not a machinist or fabricator most of the fabrication work has been done my a mate inbetween jobs, i will let him tig it up he is not really experianced with ally but his welding on the whole is very good so i trust him, iirc the injectors are 28 degrees from horizontal they were also positioned as close to the flange as possible as iirc the closer they are the steeper you can have them, the optimum would have been 25 degrees iirc for this head, i have the misab plates to seal the head with the rubber washers i will try and get a pic they seem hood quality, have to say overall i am really happy with it, it all fits together nice and snug with no tape for mockup, need to make two endplates now one for the TB and other end, Joe what thickness did you use for the TB mounting plate i was thinking 10mm
If that welds together as well as it should it will be brilliant.
That fuel rail is so much better than the one I made :)
And I think the way you've set the inlets in the plenum is the right way to do it despite the comments on the earlier post.
Thanks Rod coming from you thats a compliment!
That looks the nuts mate.
if someone goes the same route i will happily scan in the drawings and list the components bought if it stops you making the same mistakes i have
10mm is what i used for the TB end, and yes my injectors are about 30 deg i think,
the Misab plates are good,cheap too!
I have had my plenum on and off loads of times (at least 20) and the misabs are only just starting to look a bit ropey. only thing is they leave a bit of a void for fuel to collect in i doubt its a problem though.
longy
Member #: 2727
Bicester
What a beautiful setup, very nice work
1972 998 TURBO SLEEPER
Kean
Member #: 341
aka T2clubby
South Staffs
Looks great mate, nice photos too!
MarkGTT
Member #: 1194
Shropshire.
thats a good looking bit of kit, good work mate.
looking very impressive
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
love it ! it looks grate so far !
