| Home > Help Needed / General Tech Chat > When should boost start to come in? | |||||||
![]() 300 Posts Member #: 1746 Senior Member Kent |
25th May, 2010 at 07:39:54pm
Well iv been having some problems with my carb where the adjuster screw didnt move the jet, so i put a re-furbed turbo carb on today took it for a spin and things seem different.
25th May, 2010 at 07:52:55pm
i dont really know what the problem is but you shouldnt have to rev it that much to pull away.
25th May, 2010 at 08:01:09pm
The problem im having is the engine is right down on power as the turbo starts to spool up between 1500-2000rpm.
Edited by tomf on 25th May, 2010.
25th May, 2010 at 09:03:08pm
Have you put your old needle in the new carb?? On 11th Feb, 2015 robert said:
25th May, 2010 at 09:16:38pm
No the new carbs got a new BDD fitted...
25th May, 2010 at 09:19:06pm
mixture affects power, power is related to how much expansion there is form the combustion, the expansion drives the turbo ect... On 28th Aug, 2011 Kean said:
25th May, 2010 at 09:28:36pm
Ah thats a very true point how silly o i look now lol.
25th May, 2010 at 09:35:57pm
well its worth poping the other needle in and seeing what happens, On 28th Aug, 2011 Kean said:
25th May, 2010 at 09:43:15pm
and getting a wideband |
25th May, 2010 at 09:43:47pm
Yes good idea ill try that tomorrow.
25th May, 2010 at 09:45:50pm
On a side note i also saw my temperature gauge go up slightly higher than normal for my journey to work (45min drive). It usually sits at about 60 but was around 65-70 today.
25th May, 2010 at 09:46:32pm
On 25th May, 2010 MarkGTT said:
and getting a wideband Thats on the top of the list of bits to buy. when iv got the spare cash.
25th May, 2010 at 09:51:58pm
doesnt a temperature rise indicate a lean mixture? Edited by MarkGTT on 25th May, 2010. |
25th May, 2010 at 09:57:42pm
Ah a google search has just confirmed that ill play with the other needle tomorrow and rirchen the mixture up a bit.
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
25th May, 2010 at 10:38:39pm
I think retarded ignition can also cause hotter running temps too.....
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
26th May, 2010 at 08:16:15pm
Well iv had a play with the fueling and timing today and iv finally got the mini running nice and smoothly (iv even got a smooth idle at 700rpm i never managed that with a distributor)
26th May, 2010 at 09:07:33pm
wait until you crank it up to 18psi.. thats lively!
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
27th May, 2010 at 09:23:17am
tom im glad your getting on with this more so than i am haha. facny popping by work and showing me maybe taking me out. i wouldnt mind having a look at a few bits on the megjolt as its the only thin ihavnt bought yet On 27th Apr, 2010 Rick.SPI said:
cant beat a good blowout. |
27th May, 2010 at 10:54:45pm
Well a bit of an odd one, i bled the boost up to 6-7psi last night and took it for a quick spin up the road and it seemed great.
On 27th May, 2010 jamz said:
tom im glad your getting on with this more so than i am haha. facny popping by work and showing me maybe taking me out. i wouldnt mind having a look at a few bits on the megjolt as its the only thin ihavnt bought yet Yea i really should be getting on with painting my k-series clubman estate and start using that, its had an MOT with the k-series lump in it for 8months now and its only done 20 miles because i havent got round to finishing it :( Yea ill pop up there sometime soon and show you, i would take you out, but its only got one seat... I was a bit wary of megajolt at first, but it was actually pretty straight forward to do in the end, and once you get the laptop plugged in and modify things with the engine running everything makes soo much more sense. Edited by tomf on 27th May, 2010.
27th May, 2010 at 11:01:25pm
i'd leave it at 4psi untill you get it to a rolling road or get a wideband fitted..
27th May, 2010 at 11:16:39pm
Yea i know what you mean thats why iv only just decided to turn it up to see the difference.
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
27th May, 2010 at 11:19:41pm
Wise words there from nick,
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
27th May, 2010 at 11:49:53pm
Cheers for the offer mate, but im a bit of a trek from Gravesend. CT3
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
28th May, 2010 at 08:33:19am
Could be a heavy lean out. I'd definately be getting a wideband on there as soon as. It's probably the single best addition I've ever made to my car. |
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
28th May, 2010 at 09:22:04am
sounds like you need to block the part throttle lean off pipe. |
