| Home > Help Needed / General Tech Chat > Leaning out on change | |||||||
25th May, 2010 at 09:31:18pm
Been doing some running in/tuning of the van. We are finding that on changing up at med/high revs that jumping back on the throttle the wideband jumps lean and we get a brief missfire.
25th May, 2010 at 09:40:09pm
i would start off by removing the spring then if its no better start experimenting with some different weight oils.
25th May, 2010 at 09:45:56pm
Is adding another spring a common thing? or is that how Turbo HIF's are? On 26th Oct, 2004 TurboDave16v said:
25th May, 2010 at 09:49:16pm
Lack of oil?
In the 13's at last!.. Just |
25th May, 2010 at 09:49:35pm
adding another spring will keep the mixture richer for longer when planting you foot down, much the same as a thinker oil will.. until the needle catches up
25th May, 2010 at 09:50:09pm
Will have another sesh on saturday then. Edited by John on 25th May, 2010. If something is worth doing, it's worth doing half of. |
25th May, 2010 at 10:14:28pm
Still goes bloody well though for 6psi On 11th Feb, 2015 robert said:
25th May, 2010 at 10:30:59pm
Do you have the part throttle lean off pipe connected? I know a lot of people are keeping this on for fuel economy, but I could never get my fueling right on transition from part to full throttle whilst it was connected.
Edited by theoneeyedlizard on 25th May, 2010. In the 13's at last!.. Just |
26th May, 2010 at 07:55:22am
It is connected. Fuelling etc was pretty good before the engine swap and on Sat after the new engine went in.
26th May, 2010 at 08:49:57am
i think the needle is either rising too fast or falling too slow, if the fuel is ok on a 2nd gear pull from say 1.5-2krpm up to redline, id say its not falling fast enough
Edited by Brett on 26th May, 2010. Yes i moved to the darkside |
26th May, 2010 at 08:59:05am
Which would indicate sprint too weak or oil too thick?
857 Posts Member #: 1778 Post Whore Northants |
26th May, 2010 at 04:46:11pm
Just keep your foot to the floor, problem solved :) |
26th May, 2010 at 05:20:58pm
On 26th May, 2010 sturgeo said:
Just keep your foot to the floor, problem solved :) So 6k in first gear everywhere then
26th May, 2010 at 05:23:55pm
no, keep your foot to the floor when you change up :) |
